ATR45. So a copy of a 3582 xr6turbo. Slightly smaller than a Garret 3582.
Internal gate. Stock manifold position
lol dam 400kw stealth, how does that even fit low mount.
Not yet Stao, the engine is still not taking timing, working through the list of culprits but Trent suspects an injector might be blocked partially. Everything else has been checked it seems.
I was a little worried it might have RB25 pistons, not RB25neo, but he tells me he ordered them from CP himself directly. Still, it seems to be the most likely cause to me, if all else fails.
The compression test came up 175 across the board which seems normal, but no.3 plug was definitely a different color, looked a little oily.
If it was just high compression the ethanol would have helped more I would have thought. Something is definitely up with it, knocking at 10 degrees isn't normal, unless you are turbocharging a KIA. :P
hahahahaha. No man. KIA's taking 15 degrees happily.
Well RB25det pistons are lower in compression to Neo pistons any way. Should have helped in knocking prevention. hopefully the engine is all good.
That's not how it works from what I have read, the neo head has a completely different combustion shape and will bump the compression sky high apparently.
The engine seems strong, and the torque graph was shooting skyward at an insane rate when I left, hopefully it's sorted soon before he burns the car. :P
Haha yeah fingers crossed just a failed injector
Pistons were a custom order through CP Pistons USA via High Octane Racing here. As no one keeps Neo pistons in stock
Picture of piston
No it works the other way around , Neo 25Ts have a lower flatter piston crown to maintain the same 9.0:1 static CR with a smaller volume combustion chamber .
The R33 25Ts have a higher raised piston to get static 9.0:1 with a larger volume chamber .
So in theory if you put a Neo head on a 33 engine the CR is higher than a std 33 . Stick a 33 head on a Neo short block and the CR is lower than a std Neo .
Smaller chamber + flatter piston is the better std system , less chamber surface area to absorb combustion heat and 4 valve engines breathe better with flatter pistons .
If you remember high comp pistons in hemispherical (Hemi) chamber engines you know about the great chunk of piston partially obstructing flow between the valves , it has to be this way because the chamber volume is so big .
Aside from more valve area without big heavy valves part of the pent roof 4 valve chambers advantage is compact chambers so you can get CRs up without high piston crowns .
I'd be comparing the pic of that piston with pics of std 33 and Neo pistons .
A .
That's what I was led to believe, so 33 pistons in a 34 neo would raise the compression by a substantial amount I would guess...
*Goes to Google image search. :P
Can confirm - RB25/26 Pistons will result in a HIGH compression ratio on a neo.
Source: my rb29 stroker kit with compatible pistons. (they aren't)
Also good to see the results of the ATR, given I was going to try something almost identical, (or a SS4-5 compressor) and 30psi.
If my car stops exploding.
A .
Definately a Neo Piston.
This is a Neo piston from my old stock engine
Stock Rb25det piston from google
Isn't everyone over east? :P
Stao only uses one casting of .82 internal gate housing for skylines as far as I know, I have asked him for an external housing a few times but it would obviously blow the cost out, as he is tooled up to cnc the internal. I can weld a gate to the housing easily as I have a jig and know where the gate will clear. You would need to organise your own screamer/plumb back pipe locally.
I have to jig up a stock manifold for a suitable gate position still, so I can't really make one until I have an rb25 on the hoist, and a spare manifold. I was hoping to get over to Stao's to check his out, but he is the other side of the city, and we are both too busy atm. Hopefully I could sell it as a kit eventually with the gate and screamer pipe, but is there much of a demand for this setup? I would need to set up a cash back on return system for the old stock manifolds.
Welding off the housing would be best for shipping purposes obviously, and there are so many cheap options out there for housings now, like the stainless Vband Tial copies I use on my car, which make turbo/exhaust swaps so easy compared to the 6 bolt Nissan.
Why u make so hard to choose!
I may just need to go of the housing for now then if its to involved atm to get done on the Stock manifold.
I personally want it because ill be keeping Low mount on my car and dont want the bling of top mount.
Could the below be done if Gate on manifold is to hard.
If i send the turbo to Stao to upgrade to SS2 and he can send to you, you can then put Gate on housing and weld internal.
( Stao can keep internal actuator as a present? )
On a crappy tight schedule aswell because of racewars :(
But i do still have till about 30th March.
Yes Jarod, PM me about it if you like. We have done that recently and it worked quickly, other than shipping times... it isn't much work for me. He likes to check them after welding I think, just to make sure, but the last one was fine I assume Stao?
I would also need the gate, Vband preferably. Do you have a local fabricator that can do the screamer?
I'm still waiting from Stao to send me back the housing, I was hoping to fit the turbo up this long weekend and send it to the exhaust shop during the week :(
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
