It's a system. Compressor + engine + turbine determines if the compressor will run out of flow or not. Put a small back end on and you may not run out of compressor flow and so hold boost to the redline. Put a larger rear on it, relieve the back pressure on the engine, might be another story entirely.
I like the analogy used on here the other day (in some thread or another) about comparing apples and oranges to work out which is the best banana.
  • Like 1
Some update, did some tuning last night and ramped it up to 1.1 bar already.. appears my stock injectors are about to hit a brick wall. I've dialled in more fuel however I've notice I had to add in heaps to get it under 11.8 AFR.
For those interested, attached is my fairly relaxed timing map :)
I tried to add more timing after 5000 rpm, but experienced some knock around the 5200 ~ 5600rpm part (which does't make much sense as I'm past max torque). Will check my CAS again.
^ hahahhaa.... I'm on a budget man, this Adaptronic ECU was super impulse buy @ $700 !
I was planning to stretch Toshi's remap till after the financial year, but this was too tempting LOL
NAOOO to top rail, CBF.. too much effort LOL
Can you get 1200cc OR 1000cc sidefeeds? we can talk after my tax returns haha
I have a spare set of brand new FiveO 1200 CC for $750 if interested.
The 16g is abit small for what I was after, might be shifting that to the SS1 turbine and see which one is better out of the two.
I will be evaluating the current 18.5 or 20.5G billet comp wheels down the track.
The only side feeds I can get are the 550's, as that's the largest they made from the factory. Anything larger is a 'highflowed' injector, essentially drilled out.
Top feed rail and Xspurt 1000's are an easy upgrade, and would cost around the price of the FiveO injectors alone. Local warranty can come in very handy too, it can cost more than the injector is worth to send it back for warranty replacement.
hrmmms.. let's see after tax returns :)
The bank account isn't happy at the moment, from my impulse buy lol
No the std evo 9 turbo with cams and supporting mods have no issue at holding 25psi till redline on my brothers car evo 8 before he got it flowed by Tao
The ss1.5 is even larger more like 20g size
Actually the SS1.5 is smaller then a 20G. That one which you've sent back originally was a 20G size. Regardless the compressor don't matter that much, the turbine side is the one needs to be worked on.
The SLSS2 stopped making power at 385rwkws at 23psi on my R33 externally gated on high mount. Usually smaller engines needs more boost getting the same power level. How ever the EVO is internally gated (stock manifold?) The easiest way to determine wither the turbocharger or some thing is maxed out is by judge the amount of power gain per psi of boost added. The percentage starts to decline sharply when that happens, and best leave as that. By calculation this the SLSS2 will max out at 299awkws at 29psi. Did that evo ended up adding higher boost for the dyno show?
Well it advertised off kando as a std evo9 16g6 but billet
Even though it was a 20g it was responsive 25psi by 3600rpm
But even people with the standard cast evo 9 turbo get the same results
My bro evo should be coming back today from tuner got head stud installed aswell as 30psi
Stao what about run a big compressor wheel in a small turbine housing then use a large internal waste gate to compensate heat and flow? I have seen few turbos from Euro cars been made that way like the Audi K03 and K04. Might be a good thing to try on.
Keen to hear the SLSS2 results, please update!
I thought the recent post to Evo Oz was actually SLSS2.. So it was actually the Kando thing?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
