Anyone care to share pics of their SS2 high mounted on an RB25? Preferably on a 6Boost manifold.
Also stao, can you run a rear turbine housing like the one on the T67 (which goes straight to Vband and doesnt have your 5 bolt IWG/EWG adaptor) on the SS2 at all? I test fitted a GT3076 on the 6BOOST manifold and it fitted fine but the SS2 front housing hits the cam covers.
I email'd Kyle (owner of 6BOOST) and sent him some pictures and measurements of the manifold. His response was that all manifolds come off the same jig and mine isnt any different to a standard item. He also said
"At a guess id say the hypergear turbine housing is bigger or the offset of the scroll closer to the flange centerline making it bulge out the rocker cover side more and hit. Borrow a proper Garrett turbo off someone and try it.
Regards, Kyle"
looks like you've got 3x options really:
  • Get Stao to get you another exhaust housing, something a little shorter so it brings the turbo down
  • Modify the manifold (probably worst option)
  • Get a Garett Turbo (probably close to worst option also)
Regards, Kyle"
That is BS
Ask him why other people using his Rb25det high mount manifold and this particular turbo fits.
All P Trimmed T3x turbine housings are identical. Its the "Area" over Radius that made up that volume which hits the rocket cover. To space it out, this area will have to be minimized, means no longer .82.
Also look how close this back plate is to the head. There is no way this comp housing can fit even the turbine housing is changed.
I've seen 6 boost manifolds high mounted SS2 with .82 turbine before. This manifold is very wrong.
The only way I see it, is by cutting off the manifold flange and re-weld it in the correct angle.
Surely people can understand my situation. I have 2 reputable people (Hypergear and 6Boost) both telling me that it's not their product that is at fault. I just want to know what my issue is.
That's why I asked for pictures of other people setups to be 100% sure that the turbo is fine.
If you look at thr manifold, the angle seems pretty aggressive so it brings the turbo closer to the head.
Can't be the turbo, all the exhaust castings are the same. If that's the case then every single turbo Hypergear sells would need different manifolds each time, however every turbo fits as it supposed to low or high mounted.
Even look at Cal's SS2, has been mounted in the most unconventional way and fits.
It's no big deal to cut and shut the flange to angle it away from the head, but obviously Kyle is unwilling to do that? Poor service indeed... You could possibly machine it, or weld a wedge shaped flange to the top?
I suggest you take it to another fabricator and never speak of 6boost again.
<p>looks like you've got 3x options really:
Another option would be a custom made angle spacer, between turbo and manifold.
Which would be weird! I can help out there if needed.
Edited by superben
383rwkws with 23psi by 3500RPMs standard spec rb25det engine on single scroll high mount and external gate E85. Thats about the limitation of most power and response. any thing more it starts to chock the engine down low and doing opposite. It feels as stock turbo pulling 383rwkws. No point getting any better response beyond this point.
That was with the old SS2 CBB CHRA, the new one can probably fetch 390rwkws.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
