Anyone care to share pics of their SS2 high mounted on an RB25? Preferably on a 6Boost manifold.
Also stao, can you run a rear turbine housing like the one on the T67 (which goes straight to Vband and doesnt have your 5 bolt IWG/EWG adaptor) on the SS2 at all? I test fitted a GT3076 on the 6BOOST manifold and it fitted fine but the SS2 front housing hits the cam covers.
I email'd Kyle (owner of 6BOOST) and sent him some pictures and measurements of the manifold. His response was that all manifolds come off the same jig and mine isnt any different to a standard item. He also said
"At a guess id say the hypergear turbine housing is bigger or the offset of the scroll closer to the flange centerline making it bulge out the rocker cover side more and hit. Borrow a proper Garrett turbo off someone and try it.
Regards, Kyle"
looks like you've got 3x options really:
  • Get Stao to get you another exhaust housing, something a little shorter so it brings the turbo down
  • Modify the manifold (probably worst option)
  • Get a Garett Turbo (probably close to worst option also)
Regards, Kyle"
That is BS
Ask him why other people using his Rb25det high mount manifold and this particular turbo fits.
All P Trimmed T3x turbine housings are identical. Its the "Area" over Radius that made up that volume which hits the rocket cover. To space it out, this area will have to be minimized, means no longer .82.
Also look how close this back plate is to the head. There is no way this comp housing can fit even the turbine housing is changed.
I've seen 6 boost manifolds high mounted SS2 with .82 turbine before. This manifold is very wrong.
The only way I see it, is by cutting off the manifold flange and re-weld it in the correct angle.
Surely people can understand my situation. I have 2 reputable people (Hypergear and 6Boost) both telling me that it's not their product that is at fault. I just want to know what my issue is.
That's why I asked for pictures of other people setups to be 100% sure that the turbo is fine.
If you look at thr manifold, the angle seems pretty aggressive so it brings the turbo closer to the head.
Can't be the turbo, all the exhaust castings are the same. If that's the case then every single turbo Hypergear sells would need different manifolds each time, however every turbo fits as it supposed to low or high mounted.
Even look at Cal's SS2, has been mounted in the most unconventional way and fits.
It's no big deal to cut and shut the flange to angle it away from the head, but obviously Kyle is unwilling to do that? Poor service indeed... You could possibly machine it, or weld a wedge shaped flange to the top?
I suggest you take it to another fabricator and never speak of 6boost again.
<p>looks like you've got 3x options really:
Another option would be a custom made angle spacer, between turbo and manifold.
Which would be weird! I can help out there if needed.
Edited by superben
383rwkws with 23psi by 3500RPMs standard spec rb25det engine on single scroll high mount and external gate E85. Thats about the limitation of most power and response. any thing more it starts to chock the engine down low and doing opposite. It feels as stock turbo pulling 383rwkws. No point getting any better response beyond this point.
That was with the old SS2 CBB CHRA, the new one can probably fetch 390rwkws.
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
