Received my billet ss3 for Hypergear a few weeks ago
Can not wait to finish fitting it up to this 58,000k originally bone stock auto motor
And run it it my daily driven and weekend tracked Silvia
Will update again when the results are in, excited is an understatement I have big hopes for this package
  • Like 1
Generally I see Rb20det engines using the same turbocharger been 1000RPMs laggier then as if its used on a RB25det engine.
So the SS2 Alpha mentioned above should be making full boost around 4500RPMs on a Rb20det, power based on same boost is about 10% less up to certain point that RB20dets no longer makes power while RB25dets keeps on making power.
I email'd Kyle (owner of 6BOOST) and sent him some pictures and measurements of the manifold. His response was that all manifolds come off the same jig and mine isnt any different to a standard item. He also said
"At a guess id say the hypergear turbine housing is bigger or the offset of the scroll closer to the flange centerline making it bulge out the rocker cover side more and hit. Borrow a proper Garrett turbo off someone and try it.
Regards, Kyle"
Bugger....out of interest is that a new manifold or used?
Brand new, completely unused. It should be known that i bought it off another member of this forum unused as well, not direct from 6boost. Just my luck though :(
Anyone have a pic of there 6boost on cause from pics the angle of the manifold definitely doesn't look right.
That's what i was thinking, that's why i asked for pics. I was looking for your engine bay manuel but couldn't find it, i'm sure there is a pic in this thread somewhere.
I did toy with the idea of an angled spacer, or cutting the flange off and remounting at a different angle but the inside is all die grinded smooth at the collector and its all really nice. Would rather not do that but if i have to.......
Actually an angles spacer would suck as the nutss would contact the turbo at the wrong angle.
Cut off re weld, has to be done.
It can be ground again smooth.
Edited by superben
The thickness of the flange to the head and what appears to be some scale on the manifold made me think it may be. An easy option would be bolt the manifold to a dummy plate, grab an oxy and lever it 5-10mm. Heat the right places and science will do much for the work for you. Much easier than cutting and welding
that sux balls dude, but superben is on the money...it can be made pretty again...just cut and reweld the flange at the right angle....then ...make it pretty and make ceramic coat it.
Yeah my pics is here but my manifold is brae not 6boost but here it is anyway.
Decided not to paint my cam covers blue today thinking it would be too try hard and wouldn't look too good so I went with black and then I see this picture. Damn you, that's so nice! lol
Had my rb20 tuned yesterday with Unigroup.
OP6 Highflow.
240rwkw, 20 psi, full boost around 4800rpm. 98 fuel.
Ran out of time to adjust cam gears, tuner thinks he can get approx 500rpm better response.
Car still uses stock r32 airbox, return flow cooler, engine bay looks stock.
Comes on hard, is lots of fun to drive.
Car makes some cool spool noises from inside :) Very happy so far.
Will post dyno graph up tonight, left it in the car.
4800rpm from an OP6 highflow on an RB20 is fairly reasonable I believe, also making the right power for a bolt on for an RB20.
If Yavuz thinks he can dial it down another 500rpm and not lose any power that would make for a pretty good bolt on result. Props.
Nice power, that's gotta be fun - though 4800rpm is pretty nasty, even for an RB20.... hopefully that spool can be improved as suggested as it's not that flash at the moment at all, imho.
Hmm, I don't think its that bad man. A stock OP6 is pretty laggy on a 20, so I don't anticipate a highflow to be much better.
Not to say that 4800rpm is great spool but I do think its on par.
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
