My Hypergear SS2 external version in action at Wakefield Park just this Tuesday.
Track was pretty wet and I was one of two cars on the track at the time - thought I would have a little fun :)
  • Like 1
Looks like you had some fun out there. You ran the 1/4 yet johnny? Be interested yo see how the ss2 went :)
Need to sort out my voltage drop at high RPMs, it's causing the miss fire (I'm lead to believe).. been only running 1.3bar instead of 1.6bar
Haha I see granny shifting
not doubling clutching LOL...
  • Like 1
Okay so after going to WTAC and FD Asia on the weekend and hearing the RX7 running 13B+T51R I am in love!
Thought you would be the best person to ask stao, what exactly makes the massive turbo spool/whistle sound that the T51R is known for? It sounds so good haha, you should make a one off SS2 for me that sounds like that!
ex gate sounds good johnny!
  • Like 1
T51R, the maximum I've seen is 646rwkws on E85 Fuel, that was on a LS1 V8 motor. Our ATR46 is actually an larger turbo but not suitable for any thing smaller then a 4L.
I can drill some holes on the comp housing and make a SS2 sound much louder :D
It will becomes laggier, So you are trading turbo response to turbo Noise. lol
I can make some plug to go with it that you can rise or lower the vacuum cleaner volume, and adjust the amount of response for the amount of noise.
It should be super responsive on your 3L now, So I guess it doesn't hurt turn on full volume.
TAKE MY MONEY TAKE MY MONEY!!!!!!!
I want :)
A turbo that makes poofy noises? :/
lol.. and?
I know you hate my flutters/the sphincter of the universe t u r k e y noises & gate... but it's delivering an experience :)
  • Like 1
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
