A bit OT but how are you graphing all your logs like that johnny? Neat and easy to digest :)
it's just excel :)
I create pivot tables with filters then create graphs from it
Alrighty, part where everyone gets excited..
Details:
  • Hypergear SS2
  • 45mm Turbosmart External Gate off Housing (thanks scotty_mn35)
  • E85
  • 1.6bar boost, made more power on 1.5bar
  • IAT shot up to 50 degrees, subsequently lost 3 degrees of timing (I take 1 degree off every 5 degrees above 35)
  • Stock motor
  • Stock manifold, stock plenum
Timing Map:
Dyno Reading at Power Tune:
Virtual Dyno Reading (Using Log File on the same run at Power Tune):
  • Like 2
That thing must feel like a missile when it's on boost. There is a LOT of phat under that curve.
awesome result. just out of curiosity did you try to add timing and lower boost in the top end while on the dyno to try pull IAT's down a bit? if so what happened?
Edited by Blackkers
Car was just at a dyno day at Powertune so I wasn't controlling the runs..
I did tell Chea to run the car with different boost settings, but at 1.6bar it bled down to 1.5bar. Ended up doing 1x run at 1.5 bar and 2x runs at 1.6bar...
I'll upgrade the FMIC and then hire out a dyno and pump more timing through the motor. Adam at Powertune did say my manifold was glowing red by the 2nd run. Signs of high EGTs and/or flow restrictions.. probably won't get round to doing any of what I said till February.. barely have time to do anything with the car these days lol
Johnny,
Your approach is probably wrong. 50°C IAT is nothing. Certainly not enough to be pulling lots of timing out. You really need to listen for knock properly and decide where/when it becomes apparent and make the tune safely away from there in the usual manner that people have always done. When you're pulling timing at those relatively mild IATs, you're causing high(er) EGT.
You're using E85 which will smother the effect of hot air a lot better than 98 will. Gives you so much extra protection that you're probably massively overdoing the engine protection routine by backing off the timing the way you are. If you wanted to be fussy about it you'd be better off pulling boost off it as the IAT goes up.
Problem is with E85 you can't really hear knock.... I do monitor for knock but regardless of timing or boost levels put through the motor the knock readings are pretty similar (mind you it's just a basic knock monitor I'm using with the Adaptronic).
I was always under the impression IATs past 50 degrees Celsius is bad, thus I pull back 3 degrees at that point.
Most of the runs have been with Virtual Dyno used to estimate torque/power gain. I did some logging when I was at Wakefield too with the laptop under the front seat strapped down.
I can't pull boost as IAT increase as the ECU doesn't have that feature and also I use a dedicated EBC which allows for quick changes of settings.
In saying that the tune isn't complete, I haven't hired a dyno to finalise and push the tune further as I was still ironing out some bugs.. hopefully will do that after the new year once the shop I hire the dyno opens back up for business again.
Ok, so I did some quick reading of a few engineering papers and this came up - although it's for a direct injected motor..
Looks like I may be a little too cautious with the whole IAT vs. Timing.
Just a note 3 day turnaround Maybe??? ,Then 7days to post back WTF??? ,if you go this route make sure you ask for an express post return , don't assume they will post it express unless you ask !! And yes I did call and ask about the turna round time ,etc etc , just sayin so others don't get caught with with a car siting in a work shop
Express option is available to chice from on our site, default is parcel post with insurance. How ever during xmas break delivery time can be unpredictable.
It wasnt Christmas it was last week of November ,I asked if I could check out on line and they said do it COD ,I am just giving a heads up so others don't get caught out .
I have had similar issues with COD it can take Aust post ages. One of my deliveries took a week, sent from the other side of Melbourne. lol.
Not Hypergear's fault. Pay for a courier if you want express delivery.
Yeah COD is often awkward like that. I had waited a while before checking with the post office that said they'd had it for a week... I was never notified. Not hypergear's fault though and the turbo was worth the wait!
Hope every one had a lovely new year. :turned:
I've spent a lot of time but haven't had alot of luck with the GTR yet, I've fitted over 20 different combination of turbochargers to it and yet can not get it to reach 20psi any quicker then 4300RPM. Due to the lack of VCT, the head doesn't like boost down low either, result in a violent surge working with smaller turbochargers, Then the only way out is by creating more lag.
How ever I'm narrowing down to a few sets of wheel and housing combinations for the most responsive 400awkws as possible. Will be doing further evaluations with it using adjustable cam gears down the track.
Result sent in by another member that is currently using our 21U high flow running E85 fuel making a super responsive 311rwkws on 20psi internally gated. That is on a R33 Rb25det stock engine.
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
