A bit OT but how are you graphing all your logs like that johnny? Neat and easy to digest :)
it's just excel :)
I create pivot tables with filters then create graphs from it
Alrighty, part where everyone gets excited..
Details:
  • Hypergear SS2
  • 45mm Turbosmart External Gate off Housing (thanks scotty_mn35)
  • E85
  • 1.6bar boost, made more power on 1.5bar
  • IAT shot up to 50 degrees, subsequently lost 3 degrees of timing (I take 1 degree off every 5 degrees above 35)
  • Stock motor
  • Stock manifold, stock plenum
Timing Map:
Dyno Reading at Power Tune:
Virtual Dyno Reading (Using Log File on the same run at Power Tune):
  • Like 2
That thing must feel like a missile when it's on boost. There is a LOT of phat under that curve.
awesome result. just out of curiosity did you try to add timing and lower boost in the top end while on the dyno to try pull IAT's down a bit? if so what happened?
Edited by Blackkers
Car was just at a dyno day at Powertune so I wasn't controlling the runs..
I did tell Chea to run the car with different boost settings, but at 1.6bar it bled down to 1.5bar. Ended up doing 1x run at 1.5 bar and 2x runs at 1.6bar...
I'll upgrade the FMIC and then hire out a dyno and pump more timing through the motor. Adam at Powertune did say my manifold was glowing red by the 2nd run. Signs of high EGTs and/or flow restrictions.. probably won't get round to doing any of what I said till February.. barely have time to do anything with the car these days lol
Johnny,
Your approach is probably wrong. 50°C IAT is nothing. Certainly not enough to be pulling lots of timing out. You really need to listen for knock properly and decide where/when it becomes apparent and make the tune safely away from there in the usual manner that people have always done. When you're pulling timing at those relatively mild IATs, you're causing high(er) EGT.
You're using E85 which will smother the effect of hot air a lot better than 98 will. Gives you so much extra protection that you're probably massively overdoing the engine protection routine by backing off the timing the way you are. If you wanted to be fussy about it you'd be better off pulling boost off it as the IAT goes up.
Problem is with E85 you can't really hear knock.... I do monitor for knock but regardless of timing or boost levels put through the motor the knock readings are pretty similar (mind you it's just a basic knock monitor I'm using with the Adaptronic).
I was always under the impression IATs past 50 degrees Celsius is bad, thus I pull back 3 degrees at that point.
Most of the runs have been with Virtual Dyno used to estimate torque/power gain. I did some logging when I was at Wakefield too with the laptop under the front seat strapped down.
I can't pull boost as IAT increase as the ECU doesn't have that feature and also I use a dedicated EBC which allows for quick changes of settings.
In saying that the tune isn't complete, I haven't hired a dyno to finalise and push the tune further as I was still ironing out some bugs.. hopefully will do that after the new year once the shop I hire the dyno opens back up for business again.
Ok, so I did some quick reading of a few engineering papers and this came up - although it's for a direct injected motor..
Looks like I may be a little too cautious with the whole IAT vs. Timing.
Just a note 3 day turnaround Maybe??? ,Then 7days to post back WTF??? ,if you go this route make sure you ask for an express post return , don't assume they will post it express unless you ask !! And yes I did call and ask about the turna round time ,etc etc , just sayin so others don't get caught with with a car siting in a work shop
Express option is available to chice from on our site, default is parcel post with insurance. How ever during xmas break delivery time can be unpredictable.
It wasnt Christmas it was last week of November ,I asked if I could check out on line and they said do it COD ,I am just giving a heads up so others don't get caught out .
I have had similar issues with COD it can take Aust post ages. One of my deliveries took a week, sent from the other side of Melbourne. lol.
Not Hypergear's fault. Pay for a courier if you want express delivery.
Yeah COD is often awkward like that. I had waited a while before checking with the post office that said they'd had it for a week... I was never notified. Not hypergear's fault though and the turbo was worth the wait!
Hope every one had a lovely new year. :turned:
I've spent a lot of time but haven't had alot of luck with the GTR yet, I've fitted over 20 different combination of turbochargers to it and yet can not get it to reach 20psi any quicker then 4300RPM. Due to the lack of VCT, the head doesn't like boost down low either, result in a violent surge working with smaller turbochargers, Then the only way out is by creating more lag.
How ever I'm narrowing down to a few sets of wheel and housing combinations for the most responsive 400awkws as possible. Will be doing further evaluations with it using adjustable cam gears down the track.
Result sent in by another member that is currently using our 21U high flow running E85 fuel making a super responsive 311rwkws on 20psi internally gated. That is on a R33 Rb25det stock engine.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
