Yes that Mac solenoid went funny on the start and we could not run any thing less then 23psi. it was later replaced. High boost was tuned first then low boost. I think this is what blew one of my Rb25det engines few years ago.
Ok there's possibly a few things going on there that make direct comparison difficult. What difference/similarity in spec between those 3 for exhaust manifolding, exhaust system, inlet pipe/filter, and intercooler/piping?
The two GTRs are very similar, R32 had a 6boost high mount, same size cooler that was supplied and installed by the same fabricator. the GTST had hybrid NZ manifold and the usual cross over pipe front mount cooler kit.
All cars has factory cam gears, while the GTST has VCT. All tuned on the same dyno using the same ramp parameters.
Wasn't hard to guess. They are junk and all block with E85. I don't know why people bother
I bet I have put more tanks of ethanol through my set than anyone, without any issues...
Blaming your injectors for a poorly filtered fuel system is a little silly isn't it?
Been speaking to Stao but I'll ask anyway:
Which turbo would be recommended for ~100rwkw at 3,000rpm / full boost by 3,000rpm and around 240rwkw?
If possible a bolt-on solution which retains the stock 21U housings.
How long have you left e85 sitting in the rail for as we had an evo at my shop never had an issue ran on e85 for a few years now, left to sit for around 6 months and when starting idle was shit house and wouldn't rev right, afrs f**ked. All injectors were gunked up, dropped in a new set of the same ones (Id's) and back to perfect. Only issues I've seen if when the cars been left sitting for long periods of time. Running lots of fuel threw em and not having it sit generally gives no issues
There are few persons that I speak to that had issues with gunk blocking injectors, they all appears to have the type of injector that has the four small spray holes on the nozzle. The ID Bosh single ping spray type of injectors seems to be less problematic.
All EV14's?
Not all, the Bosch branded ones that are around $100 from Sonic performance seem to have issues.
Ummmm no. I have never had a set, I've always used Deatchwerks without issue but going to events and watching my friends competing have 3 sets of injectors for when they block is fairly amusing.
I've seen around half a dozen different cars all with issues of these injectors blocking, all with different and more than adequate filtering systems. One car evern changed filter set ups 3 or 4 times and still had issues, funnily enough swaped to a different type of injector and never an issue since.
If you have these injectors and they work that's great for you but don't you run Xspurt? I'm yet to see a car with these injectors on E85 that don't have issues
Edited by SimonR32
Time for a dedicated thread on these issues I reckon?
I'm thinking Scott Black's on the money here. Sounds broadly similar to what happens with methanol - the hardware doesn't cope well if the fuel is left to sit in tanks and lines. Maybe not in all instances with E85, but reports are common enough and seem to involve those cars being left to sit between events and maybe running a few times per year.
I'd like to hear what happens for those guys who drain their tank and purge the system with petrol.
add some Lucas Ethanol stabiliser into your tank, I do that and last time I removed my injectors they were clean as the day I got them..
Also note, I do like 3000km per year on my car - it doesn't get driven much.
My car did sit around for about 3 months when i did the transplant to another shell with a different tank that hadnt had e85 in it before.
So i think it was a combination
1. Car sitting around for longer than normal
2. New tank hadn't run e85 before and was sitting around even longer than 3 months.
3. I dont run filters on my EV14s
I have the SS2 and while it would be pretty close to 100rwkw at 3k (it's between 95 and 100) full boost isn't made until around 3700-3800. I'd probably go the highflow for those targets. The OP6 highflow has been over 300rwkw a few times with E85 so you do have a bit of head room if you wanna turn it up
Had the OP6 highflow on pulp, it was good up top but not as responsive as I wanted. I think I'm gonna get an SS1 built into the factory housings. Should have similar response to an SS1PU according to Stao. Full boost by ~3500rpm and ~90-100rwkw at 3,000rpm.
250rwkw is more than enough for me on the street. Response is what I'm ultimately after.
Edited by colourclassic
  • Like 1
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
