Hey Stao,
Finally got around to fitting a 21U highflow i bought off you half a year ago as the gt2871rs finally died from track abuse lol.
Couldn't be happier with performance. Similar (and i think slightly better) response than a gt2871rs but much stronger mid and top end when on hi boost.
Final figures were 21psi for 305rwkw track friendly tune, wastegate pressure gave 270rwkw which was around 18-19psi.
Tuner mentioned he was very surprised by the turbo and impressed with the smoothness/power delivery.
I'd offer dyno printout but we tuned it on crap road tires and high boost just ended up wheelspinning on the dyno haha, causing a really jagged powerline.
Will also mention power comes on much more progressive than my old turbo, so much so that even at high boost, my car grips 2nd with no fuss and this is all on a circuit setup so camber, toe, stiffer springs/dampers etc.
Thank you :)
This makes me really keen to install my 21u highflow I just got :)
Thanks for the feedbacks guys.
I should have enough time in finishing off the GTR before the car gets sold. With the XR6, I'm looking particularly into manual FG turbos and good ones are quite pricey. I've done few big custom built turbos for BAs and even with 1.26 rear running a 120mm compressor they spooled up like high flows on R33s. Most people are more concert about bending con-rods and snapping drive trans instead.
I will be into making GT45 equivalent CHRAs and see how they work inside stock FG housings.
so you going to try fit a 79mm ish inducer and 80mm turbine into the t3 1.06 housing and .70 t04s comp cover(or factory .60?)
i really have no idea, but i would have thought the money /market share would be in GTX3582 to 64-67mm inducer to4z sized bolt on stuff? Thats high 9 sec stuff already in a big falcon
if you did that, you would also cater to the Rb30 sohc and 3.0l skyline crowd with just a exhaust housing change and kill 2birds with one stone
cheers
darren
Edited by jet_r31
Testing and evaluated our latest turbocharger for the GTR33. This is a Special Application Turbocharger engineered to be externally gated working with Rb25det an Rb26det engines.
This is the most responsive single turbocharger that ever made 411rwkws on Trent's dyno out of a standard Rb26dett engine.
Peek 411rwkws @ 26psi E85 fuel
We took a few runs to setup the EBC and this is power and boost graphs from 20psi to 25psi.
Vs an other RB26dett with similar mods using a GT3582 in .82 rear:
This used to be the former most responsive single for a RB26det. This car is running HKS270 Dur cams, with Active VCT inlet cam. It is using an Garrett GTX3582R.
ATR45 SAT managed to beat it in both peek power and responds using factory cams and cam gear. However even I've had more boost down low, the VCT head always had the advantage of drawing more air. Dark blue and Red are running similar boost levels.
Against my TD06SL2-20.5G in 10cm Turbine:
Light blue: ATR45 SAT, Dark Blue: TD06SL2-20.5 in 10cm Turbine.
In theory, fitting this turbocharger on a Rb25det, it should produce the identical responds as a TD06SL2-20G in 10cm turbine, while maxing out over 400rwkws.
I'm pretty happy with its overall outcome. I will be doing further evaluations with few more wheels that I've made, hopping to reach better power and responds.
  • Like 1
Not trying to knock your result Stao but i noticed you only ran the 35R up to 25psi?
A 35R will keep making power past 25psi no worries. So not an entirely true statement about making more power than the 35R ;)
Stao are you able to highflow GT2860-5 turbos to GTX2867 or equivalent? I bought a parts car that was making 360rwkw on 98RON with the 2860's but i'm hoping to go a bit further than that.
Edited by Super Drager
I've posted results on different boost levels, so its not necessarily of making more power but much better response and drive ability. When I trailed GT35 with my forged RB25det it stopped making power at 431rwkws at 29psi, This particular turbo will be making the same amount of power except I don't think this engine will take that boost. Goal is responsive 400awkws, this is the best one so far and I'm trailing an updated prototype next week hopping to hit 20psi and 200awkws by 4000rpm.
Yes I can high flow GTR turbos with -5 equivalent using our ATR28G1 CHRA or SS15 which probably works out similar to a GTX2867. They are very laggy on RB26 engine tho. For the amount of money I recommending of getting a proper high mount setup and use the new SAT version of ATR45SS.
No i meant putting a GTX2867 core into GT2860-5 housings, on a VG30DETT engine though.
Yes I can machine the housings to suit. It will cost you $100 per housing to machine. I'm pretty sure their turbine wheels are the same.
Just had a quick look and yes the turbine end looks to be the same, do you think these kinugawa GTX comp wheels would be any good?
http://www.ebay.com.au/itm/Billet-Turbo-Compressor-Wheel-Garrett-GTX2867R-49-7-67-4-Trim-55-11-0-/271774042157?pt=LH_DefaultDomain_15&hash=item3f46fec82d
If its possible to machine the housings, fit and balance the comp wheel then i'd be happy.
Picked up this bad boy today after reading all 530 pages of this thread
10523565_856078507785625_194948415913983
Going onto an RB25det NEO in my R31 Ti
- Sard 650cc injectors (pretty rubbish)
- 2.5" cooler piping from turbo to t/b, 510x250x65 intercooler tube and fin (may be a restriction)
- 3" dump pipe, highflow 4" bodied metal cat, 3" exhaust with 2 straight through mufflers
- Aeromotive 340 stealth pump
- Nistune ER34 board
- Hypergear ATR43SS2 with op6 rear end to suit
- IWG welded up
- Turbosmart 40mm comp gate welded onto housing
- Screamer slash cut at passanger foot well
- 3" metal intake
- Z32 AFM
- Stock R31 airbox with highflow 'drift' filter and rear of lid chopped out (loses ALOT of power with unmodified lid, tbh most likely going to fabricate a custom airbox with panel filter.)
Hoping for 300 on P98 but will be more than satisfied with 280ish. Going to trial nistunes feature pack flex fuel most likely as well and bang some ID1000s or similar in for when i want more power. However on a R31 live rear axle with a poo rebuilt LSD that works when it feels like. will be a bit death lol.
Photo of the bay with the current GCG highflow that is going into my mates 31
10295196_10152932108354924_1802155133729
Edited by AUSBen31T
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
