Yes it is. The recommendation would be working with our high pressure actuator, that will cost you $990 inc oil line. That way the waste gate bunk can travel all the way to a full 90 leaving gate port wide open. Gives abit more top end .
In terms of the housings I can swap it over for you as I have a spare.
How well does the 43SAT go with the journal bearing instead of ballbearing? I want to buy one but not sure that I can quite afford the ballbearing option...or should I just save a little longer and hold out for the ballbearing option?
The sr20vet is running around 20psi keeping it safe on tracks.
Yes definitely recommended bb for the new sat turbos, does make a notice able difference to throttle response.
How much boost to make 330rwkw on the SR20VET stao?..im guessing not a lot..and theres a lot more left in it
FWD/AWD is totally different beast to RWD.
The different orientation engines don't make comparable power. Plus driveshafts/diffs/gearbox are holding that particular car back from more power.
Yep i know this..
I also could work out pretty easy its not on kill..that turbo is a 61mm ish comp with a 64mm rear..it would want to have plenty left ex gated..
Cheers
Darren
ATR43SS2 making 294rwkws @ 20psi P98 fuel:
Hypergear turbo z32 afm 770cc inj power fc ecu and boost t running 20psi
Been working on few new prototypes G3SAT turbos running Hybrid ball bearing combinations lately. I think I'm hitting a wall of getting any better then 20psi @ 3550RPM without comp surge. The drive ability is great however. I might be giving it to Mr Richo and see if that improves his track times.
  • Like 2
dirty plug, but if anyone wants a stock RB20DET/25DET manifold with already 55mm extended studs fitted of which 38mm is exposed at a minimum.
http://www.sau.com.au/forums/topic/463178-fs-syd-rb20det-rb25det-stock-manifold-with-extended-studs-for-hektics/
Good for Hypergear turbo upgrades :)
Some more testing and evaluation results. This is our last BB ATR43G3SAT prototype turbocharger on R34 with P98 fuel internally gated. Note the linearness in power and torque curve to 5000RPM. Turbo made 308rwkws @ 20psi.
Yes. I'm considering that. Seen few in the past few month but prefer some thing in better conditions. But need to sell at least one of my test cars first, running out of parking spaces.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
