Roughly what size turbo is that? Keeping in mind that it is going on an RB20. Only wanting absolute max 250ish kW to keep response as best as possible.
Yes can build u an atr43g2 in cbb model for rb20det, that will be responsive and max towards 250rwkws regions
Stao what version of the Atr45 do i have? i got it in dec 2013.
is it even worst then the 1st rev of the atr45sat?
do you have a graph that compares my old one to the newest?
And how much to upgrade or change to the latest?
  • Like 1
The ATR45 is a 3582 equivalent in .82 rear. It's good size turbo for a 3L bottom. The new one is a very different turbo and nothing interchangeable. Best sell that and we can build you a ball bearing one new from scratch.
On 9/16/2016 at 5:20 PM, Dose Pipe Sutututu said:
extremely funny looking graph :)
Yep, Seems the engine had broken ringland's at the time thanks to a bad 'run in tune'
Had no signs or anything obvious until after this tune. (different tuners)
New version is a very different turbo.
Thanks Stao. Is if possible to build the new SS2 to the old dimensions so that it's a drop-in replacement?
I think Johnny said you need to adjust and rotate the dump a bit to accommodate the new one.
When Tao and are selves put Are heads together and come up with the 6765 , bb core t4 split pole rear ! This should de an animal on the new set up !
Big thanks to hypergear as usual
stock Rb25 turbo for comparison
  • Like 3
29 minutes ago, 4bidn1 said:
I should really put my glasses on before typing on my phone ?.
Thats not even English
Lol...did you use talk to text?  Makes sense then being you're from Radelaide.  I'm going to call you Christopher Pyne from now on :laugh:
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
    • The frontend wouldn't go low enough because the coilover was max low and the upper control arm would collapse into itself and potentially bottom out in the strut tower. I made a brace and cut off the kingpin and then moved the upright down 1.25" and welded. i still have to finish but this gives an idea. Now I can have a normal 3.25" of shock travel and things aren't binding. I'm also dropping the lower arm and tie rod 1.25".
    • Motor and body mockup. Wheel fitment and ride height not set. Last pic shows front ride height after modifying the front uprights to make a 1.25" drop spindle.
