inmaniac Posted April 9, 2017 Share Posted April 9, 2017 (edited) 3 minutes ago, Dose Pipe Sutututu said: Nah, that's rubbish. It's not boost that blows apart motors, it's timing and or torque. I "had" a 300 000+ motor running with 1.8bar worth of boost for a good amount of time and thrashed regularly at the track too. It died about 3 years later lol Lol good to know. Ok thanks for the input. I'll chat through the options with Tao and see where I land. Edit: Was that standard internals Dose? I'm running all standard including HG Edited April 9, 2017 by inmaniac Extra Question Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7822975 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 9, 2017 Share Posted April 9, 2017 39 minutes ago, inmaniac said: Lol good to know. Ok thanks for the input. I'll chat through the options with Tao and see where I land. Edit: Was that standard internals Dose? I'm running all standard including HG Completely standard internals, even the OEM head gasket. However I did have some coolant being pushed out so I installed new ARP head studs as a band aid solution. Damage was already done, but the motor lasted another year of heavy track abuse, left plenty of mental shavings in the sump too! But yeah 18psi, street use with the occasional drag strip will last ages if you tuner has a clue about tuning 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7822979 Share on other sites More sharing options...
hypergear Posted April 11, 2017 Author Share Posted April 11, 2017 On 4/9/2017 at 4:54 PM, inmaniac said: Hey guys. Just wondering who here has experience with the standard "G2" high flow and what your real world results were? Cheers! G2 is engineered to work with stock ecu and injectors. You can still get over 240rwkws with it on decent mods and more boost. Dyno below shown customers result of 222rwkws maxing factory injectors on 13psi. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823324 Share on other sites More sharing options...
CEF33Y Posted April 12, 2017 Share Posted April 12, 2017 How's the RB20 experiment going Tao? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823501 Share on other sites More sharing options...
iruvyouskyrine Posted April 12, 2017 Share Posted April 12, 2017 Also interested. So close to pulling the trigger on a GTX3067 but if you have some solid RB20 results I may wait Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823563 Share on other sites More sharing options...
hypergear Posted April 12, 2017 Author Share Posted April 12, 2017 My Rb20det is hitting a brick wall at 215rwkws. I've installed the best possible mods to not cause any flow restrictions, and it doesn't like to make power. So far I've dynoed turbos in equivalents of: GT2871, GTX2864, GT3071, GT3076. and the most power it would make was 215rwkws with a 3076 equivalent. I've also spent alot of timing fixing the car and made sure all components runs correctly. Be aware of Ebay cam gears, Mine "0" degrees out of so called "HKS" brand is actually -5. Car's a GTS4. shown 188,000KMs, but drives solid. Silver top engine. The power band sort of falls into range of Rb20det P98 figures out of Trent's dyno. There are few odd ones that made pretty high power for the turbo size, I'm curious to know if its because their engines are healthier or if it had some sort of cams / head upgraded in their long years of running. For some odd reasons RB20dets doesn't like timing in mid range. Mine's down to 6 degrees around 4000RPM, but happy taking 13 degrees up top when there is 20psi of boost making the car feel torque less down low. E85 fixes that problem, and shift the whole power curve 1000RPM to the left with heaps more up top. At moment I'm fitting up a set of Kenford cams. I hope this will make a difference to power and I don't think there are anything else that I can do other wise. 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823656 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 12, 2017 Share Posted April 12, 2017 Should hold a timing gun when it's load held on the dyno, see if the timing isn't fluctuating due to a bad cas or timing belt deflection. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823657 Share on other sites More sharing options...
t_revz Posted April 13, 2017 Share Posted April 13, 2017 ^^ agreed. I had a bad Cas that fluctuated like this at every RPM and wouldn't take much timing and miss fired at 18psi. Adjusted belt several times but problem remained. 2nd hand CAS fixed it Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823682 Share on other sites More sharing options...
hypergear Posted April 13, 2017 Author Share Posted April 13, 2017 That was the first item came in mind, Trent tested said CAS is fine. I will check again when its back on dyno next. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823752 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 13, 2017 Share Posted April 13, 2017 What you need to do is say at X load and Y RPM, make all the surround areas all 10 degrees of timing.. then load hold the dyno at roughly that RPM and that load point/area then shine a timing gun at the motor and see if it's showing the same timing as per prescribed at on the timing map. Another possible thing that "may" have happened, check the woodruff key on the crank. It might have snapped off and both your cams vs. crank is off. I have seen it happen with my own eyes on a SR I worked on. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823756 Share on other sites More sharing options...
R_34 Posted April 13, 2017 Share Posted April 13, 2017 Can't say about other RB20 but mine loves timing, at 13psi he's given mid 30's up top, and when I had a functioning boost controller he was mid 20's at 20psi on PULP98. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823757 Share on other sites More sharing options...
iruvyouskyrine Posted April 13, 2017 Share Posted April 13, 2017 58 minutes ago, Dose Pipe Sutututu said: What you need to do is say at X load and Y RPM, make all the surround areas all 10 degrees of timing.. then load hold the dyno at roughly that RPM and that load point/area then shine a timing gun at the motor and see if it's showing the same timing as per prescribed at on the timing map. Another possible thing that "may" have happened, check the woodruff key on the crank. It might have snapped off and both your cams vs. crank is off. I have seen it happen with my own eyes on a SR I worked on. How would the harmmonic balancer be driving still if no woodruff key? I am confuse Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823760 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 13, 2017 Share Posted April 13, 2017 ^ woodruff snaps, then crank/cam drive sprocket moves just enough and jams itself with the remaining woodruff. You'll be surprised Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823764 Share on other sites More sharing options...
iruvyouskyrine Posted April 13, 2017 Share Posted April 13, 2017 Ahh yeah I get you! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823777 Share on other sites More sharing options...
hypergear Posted April 13, 2017 Author Share Posted April 13, 2017 Cars at Seven Auto motive to get those cams in, will keep everyone updated once its running. I will keep this post upated with my FB updates. fist our team took winning trophy on Vic time attack 1.35.27 last week. footage: Mr Oversteer was ranked 3rd this time due to Alternator problems: 1 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823806 Share on other sites More sharing options...
inmaniac Posted April 14, 2017 Share Posted April 14, 2017 On 09/04/2017 at 5:24 PM, Dose Pipe Sutututu said: Nah, that's rubbish. It's not boost that blows apart motors, it's timing and or torque. I "had" a 300 000+ motor running with 1.8bar worth of boost for a good amount of time and thrashed regularly at the track too. It died about 3 years later lol In case you were curious, after speaking with Toshi (who was ultra conservative, and against the G3 @ 18psi on my engine) and Tao, we came up with a hybrid that was halfway between a G2 and G3 high flow. It's going to have a larger compressor wheel than a G2 but use an OEM wastegate. The reasoning was that I didn't want to have the bigger turbo with such a high minimum boost pressure on my daily. Adding to this, my goal was rather conservative, aiming for a responsive 240rwkw+ on P98. I have a feeling I'll regret not going bigger in future haha but for now I'm sure this will be fine I also trust Toshi's judgement Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823931 Share on other sites More sharing options...
Dose Pipe Sutututu Posted April 14, 2017 Share Posted April 14, 2017 Many ways to skin a cat, Toshi likes to tune with loads of timing, loads of fuel but not too much boost. He takes the "let's throw in heaps of fuel so it won't knock" approach - which is completely fine however in the event IATs increase or you use a bad batch of fuel things can end in unfavourable ways. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823936 Share on other sites More sharing options...
inmaniac Posted April 14, 2017 Share Posted April 14, 2017 18 minutes ago, Dose Pipe Sutututu said: Many ways to skin a cat, Toshi likes to tune with loads of timing, loads of fuel but not too much boost. He takes the "let's throw in heaps of fuel so it won't knock" approach - which is completely fine however in the event IATs increase or you use a bad batch of fuel things can end in unfavourable ways. Yeah gotcha. Well I won't get everything on and tuned for about a month (stupid busy at work atm sadly) but I'll post here when it's done, we'll see how we go Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823942 Share on other sites More sharing options...
-S- Posted April 14, 2017 Share Posted April 14, 2017 Many ways to skin a cat, Toshi likes to tune with loads of timing, loads of fuel but not too much boost. He takes the "let's throw in heaps of fuel so it won't knock" approach - which is completely fine however in the event IATs increase or you use a bad batch of fuel things can end in unfavourable ways.Which is reliable? Increasing boost or add timing/fuel or a little bit of both? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823966 Share on other sites More sharing options...
GTSBoy Posted April 14, 2017 Share Posted April 14, 2017 Turbo cars make power from boost, not timing. 2 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/597/#findComment-7823968 Share on other sites More sharing options...
