Bit of Vid from Issac Gett Drift running one of our ATR45SS1 turbos in a RB2530det engine. Car made a responsive 430rwkws @ 20psi on E85 fuel.
https://fb.watch/7HcHu9Y7T8/
149757889_2869780959938971_8941706211260098626_n.thumb.jpg.82b8dcd1d09c1745c7b0936b01ec7fcc.jpg
  • Haha 1
  • 3 weeks later...
1000whp 300ZX is not something I come across every day. Powered by two of our ATR43SS-2 turbos externally gated on E85 fuel. Dyno maxed at 905rwhp @ 35psi
Actually Tao, Prabaths 300ZX did 940rwhp on Trents dyno maxing out the torque at 1200nm.
  • 3 weeks later...
I bought a 21u g3 used and it has minimal shaft play side to side , none front and back, and doesnt rub anywhere. previous owner said he ran at 19psi on rb20. do you think i should be concerned with the side to side shaft play or is it acceptable?
All turbos need to have a small movement in the shaft as the bearings relys on that clearance for rotation and oil delivery, you can that as bearing clearance. I say there should be nothing wrong with it since it came out of a fully working car. Assume its a bush bearing high flow, must make sure it runs an -4 oil line with no oil restrictors.
  • Like 2
  • 3 weeks later...
Going back to the Super responsive ATR45SS turbocharger, now fitted to an stock Rb25det Neo motor. High mount externally gated setup on E85 fuel. Car made 390rwkws @ 26psi, 22psi @ 3500RPM.
Edited by hypergear
  • Like 1
Sexual turbo setup for a basic build, great stuff Tao!
  • Like 1
  • 3 months later...
Updating on SAU about the latest result of the R34 GTR test car:
Back today at chequeredtuning with Tomei Pon cam Type B installed. Pretty interesting result to share as I never though it would make so much differences on a Rb26 engine. Using the same turbo and nothing else changed, car ended up making 444awkws @ 23psi, compare to stock cams, it made 31kws with 3psi less boost with waymore mid top end torque. It wasn't much laggier in response either.
Car has:
Stock R34 GTR Rb26 with APR head studs
HKS Cam gears 0 inlet, 0 exhaust.
Tomei 260 / 9.15 Pon cams
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Apexi FMIC
Trust 3 inches turbo back exhaust
PS2000
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS-1 Rb26 T4 Vband rear turbocharger
Final result of 444awkws @ 23psi
  • 4 weeks later...
  • 5 weeks later...
One more result to update. This is from a new version of ATR43SS-3 turbo. Car's an R33 GTST with a built Rb25det Neo motor with stock cams. Car managed to pull 466rwkws at @ 23psi, full boost by 4k, 520L fuel pump maxed.
Details of build:
#KeepitReet Nissan R33 GTST Drift car
Forge bult Rb25det Neo engine
Nitto Pistons and Con-rods
HyperGear ATR43-SS3 Pro Externally gated turbocharger
6 boost manifold and twin Turbo smart 50mm gates
ID 1650cc injectors + Walbro 520 Fuel pump
Forward facing plenum
Front mount PWR intercooler kit
Fuel system maxed at 465rwkws @ 23psi, E85 fuel.
Edited by hypergear
Another result to share. This is from one of our rebuilt and high flowed Precision 6262 turbo. Making 626rwkws on a R33 GTR.
Built 2.9L
Hypertune intake
6boost exhaust manifold
4" dump/front
Pwr intercooler
Bosch 1650cc injectors
Twin walbro 460 pumps
Plug and play link g4x
Prp coil kit
Prp trigger kit
drop in cams and valve springs
  • 4 weeks later...
Details of build:
Twicked this turbo alittle bit, Made same power, picked up another 500RPM of response and 100kws in mid range at same boost level or 23psi, still running out fuel even with an extra pump.  I think the original version of SS3Pro would peek 70kws more at full capacity.
  • Like 2
Very spicy, what dreams are made of. All in by ~4000rpm and making those numbers.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
