Bit of Vid from Issac Gett Drift running one of our ATR45SS1 turbos in a RB2530det engine. Car made a responsive 430rwkws @ 20psi on E85 fuel.
https://fb.watch/7HcHu9Y7T8/
149757889_2869780959938971_8941706211260098626_n.thumb.jpg.82b8dcd1d09c1745c7b0936b01ec7fcc.jpg
  • Haha 1
  • 3 weeks later...
1000whp 300ZX is not something I come across every day. Powered by two of our ATR43SS-2 turbos externally gated on E85 fuel. Dyno maxed at 905rwhp @ 35psi
Actually Tao, Prabaths 300ZX did 940rwhp on Trents dyno maxing out the torque at 1200nm.
  • 3 weeks later...
I bought a 21u g3 used and it has minimal shaft play side to side , none front and back, and doesnt rub anywhere. previous owner said he ran at 19psi on rb20. do you think i should be concerned with the side to side shaft play or is it acceptable?
All turbos need to have a small movement in the shaft as the bearings relys on that clearance for rotation and oil delivery, you can that as bearing clearance. I say there should be nothing wrong with it since it came out of a fully working car. Assume its a bush bearing high flow, must make sure it runs an -4 oil line with no oil restrictors.
  • Like 2
  • 3 weeks later...
Going back to the Super responsive ATR45SS turbocharger, now fitted to an stock Rb25det Neo motor. High mount externally gated setup on E85 fuel. Car made 390rwkws @ 26psi, 22psi @ 3500RPM.
Edited by hypergear
  • Like 1
Sexual turbo setup for a basic build, great stuff Tao!
  • Like 1
  • 3 months later...
Updating on SAU about the latest result of the R34 GTR test car:
Back today at chequeredtuning with Tomei Pon cam Type B installed. Pretty interesting result to share as I never though it would make so much differences on a Rb26 engine. Using the same turbo and nothing else changed, car ended up making 444awkws @ 23psi, compare to stock cams, it made 31kws with 3psi less boost with waymore mid top end torque. It wasn't much laggier in response either.
Car has:
Stock R34 GTR Rb26 with APR head studs
HKS Cam gears 0 inlet, 0 exhaust.
Tomei 260 / 9.15 Pon cams
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Apexi FMIC
Trust 3 inches turbo back exhaust
PS2000
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS-1 Rb26 T4 Vband rear turbocharger
Final result of 444awkws @ 23psi
  • 4 weeks later...
  • 5 weeks later...
One more result to update. This is from a new version of ATR43SS-3 turbo. Car's an R33 GTST with a built Rb25det Neo motor with stock cams. Car managed to pull 466rwkws at @ 23psi, full boost by 4k, 520L fuel pump maxed.
Details of build:
#KeepitReet Nissan R33 GTST Drift car
Forge bult Rb25det Neo engine
Nitto Pistons and Con-rods
HyperGear ATR43-SS3 Pro Externally gated turbocharger
6 boost manifold and twin Turbo smart 50mm gates
ID 1650cc injectors + Walbro 520 Fuel pump
Forward facing plenum
Front mount PWR intercooler kit
Fuel system maxed at 465rwkws @ 23psi, E85 fuel.
Edited by hypergear
Another result to share. This is from one of our rebuilt and high flowed Precision 6262 turbo. Making 626rwkws on a R33 GTR.
Built 2.9L
Hypertune intake
6boost exhaust manifold
4" dump/front
Pwr intercooler
Bosch 1650cc injectors
Twin walbro 460 pumps
Plug and play link g4x
Prp coil kit
Prp trigger kit
drop in cams and valve springs
  • 4 weeks later...
Details of build:
Twicked this turbo alittle bit, Made same power, picked up another 500RPM of response and 100kws in mid range at same boost level or 23psi, still running out fuel even with an extra pump.  I think the original version of SS3Pro would peek 70kws more at full capacity.
  • Like 2
Very spicy, what dreams are made of. All in by ~4000rpm and making those numbers.
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
