Bit of Vid from Issac Gett Drift running one of our ATR45SS1 turbos in a RB2530det engine. Car made a responsive 430rwkws @ 20psi on E85 fuel.
https://fb.watch/7HcHu9Y7T8/
149757889_2869780959938971_8941706211260098626_n.thumb.jpg.82b8dcd1d09c1745c7b0936b01ec7fcc.jpg
  • Haha 1
  • 3 weeks later...
1000whp 300ZX is not something I come across every day. Powered by two of our ATR43SS-2 turbos externally gated on E85 fuel. Dyno maxed at 905rwhp @ 35psi
Actually Tao, Prabaths 300ZX did 940rwhp on Trents dyno maxing out the torque at 1200nm.
  • 3 weeks later...
I bought a 21u g3 used and it has minimal shaft play side to side , none front and back, and doesnt rub anywhere. previous owner said he ran at 19psi on rb20. do you think i should be concerned with the side to side shaft play or is it acceptable?
All turbos need to have a small movement in the shaft as the bearings relys on that clearance for rotation and oil delivery, you can that as bearing clearance. I say there should be nothing wrong with it since it came out of a fully working car. Assume its a bush bearing high flow, must make sure it runs an -4 oil line with no oil restrictors.
  • Like 2
  • 3 weeks later...
Going back to the Super responsive ATR45SS turbocharger, now fitted to an stock Rb25det Neo motor. High mount externally gated setup on E85 fuel. Car made 390rwkws @ 26psi, 22psi @ 3500RPM.
Edited by hypergear
  • Like 1
Sexual turbo setup for a basic build, great stuff Tao!
  • Like 1
  • 3 months later...
Updating on SAU about the latest result of the R34 GTR test car:
Back today at chequeredtuning with Tomei Pon cam Type B installed. Pretty interesting result to share as I never though it would make so much differences on a Rb26 engine. Using the same turbo and nothing else changed, car ended up making 444awkws @ 23psi, compare to stock cams, it made 31kws with 3psi less boost with waymore mid top end torque. It wasn't much laggier in response either.
Car has:
Stock R34 GTR Rb26 with APR head studs
HKS Cam gears 0 inlet, 0 exhaust.
Tomei 260 / 9.15 Pon cams
R35 GTR coil packs
Trigger kit
ID 1650cc injectors
Twin 540 Walbro pumps+11m fuel line
Apexi FMIC
Trust 3 inches turbo back exhaust
PS2000
Nismo Front mount cooler
T4 high mount exhaust manifold
HyperGear 50mm External gate
HyperGear ATR45SS-1 Rb26 T4 Vband rear turbocharger
Final result of 444awkws @ 23psi
  • 4 weeks later...
  • 5 weeks later...
One more result to update. This is from a new version of ATR43SS-3 turbo. Car's an R33 GTST with a built Rb25det Neo motor with stock cams. Car managed to pull 466rwkws at @ 23psi, full boost by 4k, 520L fuel pump maxed.
Details of build:
#KeepitReet Nissan R33 GTST Drift car
Forge bult Rb25det Neo engine
Nitto Pistons and Con-rods
HyperGear ATR43-SS3 Pro Externally gated turbocharger
6 boost manifold and twin Turbo smart 50mm gates
ID 1650cc injectors + Walbro 520 Fuel pump
Forward facing plenum
Front mount PWR intercooler kit
Fuel system maxed at 465rwkws @ 23psi, E85 fuel.
Edited by hypergear
Another result to share. This is from one of our rebuilt and high flowed Precision 6262 turbo. Making 626rwkws on a R33 GTR.
Built 2.9L
Hypertune intake
6boost exhaust manifold
4" dump/front
Pwr intercooler
Bosch 1650cc injectors
Twin walbro 460 pumps
Plug and play link g4x
Prp coil kit
Prp trigger kit
drop in cams and valve springs
  • 4 weeks later...
Details of build:
Twicked this turbo alittle bit, Made same power, picked up another 500RPM of response and 100kws in mid range at same boost level or 23psi, still running out fuel even with an extra pump.  I think the original version of SS3Pro would peek 70kws more at full capacity.
  • Like 2
Very spicy, what dreams are made of. All in by ~4000rpm and making those numbers.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
