Kasko you need to be aware that the feeling you're after doesn't last, you do get used to it. Like you keep referring to your stock turbo giving the feeling you're after, yet if I was to go for a ride in a stock GTT I bet it would feel like I was in a Getz.
Probably the reason why modding is so ridiculously addictive.
My stock r33 felt like a super car web I got out of an auto Mazda 323 into it haha
Cheers for all the info
Heres my torque graph. Never noses over. Keeps climbing. Maybe we should all run small wastegates and let the boost climb the more the rpm increases.
What kind of pussy are you? just weld it shut like all the cool kids whistling.gif
What kind of pussy are you? Just get a eBay split dump pipe like all the cool kids.
P.S. let's be careful not to confuse rear wheel torque with engine torque...
That's... Exactly what I said. Lol.
Most likely because of my lack of VCT, my G3 doesn't build torque very quickly. It still creates a lot of torque, but it's not a steep curve. My mates TD05 actually has a steeper torque curve, despite being more responsive. It makes less peak torque and less peak power, but the shape of his curve gives his car more of the rush.
Kasko, you need to be aware that the feeling you're after doesn't last, you do get used to it. Like you keep referring to your stock turbo giving the feeling you're after, yet if I was to go for a ride in a stock GTT I bet it would feel like I was in a Getz.
Haha ok but not having VCT would make it more of a rush because below 4500rpm you would have less power but the same top end as the ECU turns it off around then anyway.
Seriously though thats what I have always thought it would be good to have boost gradually climbing to stop the torque dropping off.
Obvious problem is though on a really cold night etc because the wastegate is maxxed out the boost would climb higher and could get you into trouble. I suppose if you had the tune allow for this it could be ok.
No it didn't... Power is directly related to torque. If it made 530Nm at 4200RPM it is making 233kw at 4200RPM.
Can you explain????? My car made 625Nm of Torque but my auto could only handle 212 rwkw
No worries, DVS JEZ on this forum tuned it - he has the dyno data for it also :action-smiley-069:
As has been discussed many times on this forum; "Torque" generally can not be compared between Dynos as they measure tractive effort and the torque reading depends on the calibration of the Dyno. Hence saying your 207rwkw SR20 has the torque of a 300kw RB25 is not correct. As you can see from Jez's graph on the previous page, his 300rwkw produces "700Nm" of torque on his Dyno.
A reliable way to calculate actual wheel torque is to use the Power and RPM readings:
T = (Px60x1000)/(RPMx2xPi)
See the way I see it if you are running the max airflow a turbo can provide at redline, then that same airflow at x psi will be x+y psi in the midrange, hence you should run more boost in the midrange to make the most of the turbo.
Like if you look at the compressor map then the same airflow at redline at 20psi is 25psi in the midrange. So if you can get away with running more boost at redline, you should increase the midrange boost to make the most of it.
Which is why I think turbos should be set based on airflow not psi. Though if you do it this way you are always going to have a massive midrange spike and have torque fall off by redline which just doesn't feel as good for some people, though for drifting etc it is perfect.
Thoughts people?
625nm of tractive torque, not torque at the engine, dynos don't measure engine torque they measure tractive effort.
if you are making 530nM at 4200rpm then you are ALWAYS make 233 kw at 4200rpm, it isn't possible to be anything else.
Edited by Rolls
Tomorrow night. A customers tyres got slashed at his place so ive finally got some dyno time to my self. Will post in kando thread
Must have been my exhaust that rowelled everyone up lol
FKN NOISY ASS CAR *slashes wrong dudes tyres*
The reason behind that is because your car is running on E85, High mount exhaust manifold and external gate.
Run pump 98, internally gated with stock manifold. That power and torque figure will drop significantly after 6000RPM. which is like:
There are lot more to think about when building a turbo made to perform on Pump 98 and internally gated. A turbo that can deliver performance internally gated on pump 98, has no issues cracking the extra KWs on external gate with E85.
Thoughts people?
Yeah if your car can put the extra mid range torque to the ground then sure. And that is specifically to do with a turbocharger.
In my previous setup it would spin the tyres when it hit boost in the mid range and then torque would fall off higher in the rev range so when you finally got traction it had lost a lot of torque.
I am more talking from a traction point of view. As speed increases, the greater torque you can put to the ground without wheelspin. Therefore ideally for maximum acceleration given a set amount of traction you would have torque increase with rpm.
From a traction perspective totally agree, in fact you see a lot of factory cars do tricky things to do exactly this, a sharp rise in torque almost always induces wheelspin.
Look at the 3L TT inline 6 BMW engines, all sorts of trickery to keep the torque flatish and not have massive peaks like our cars.
    • First time trying out a regularity format at the Peter Hall Memorial 6hr. It was an interesting experience with everyone on our team being brand new to the format. Safe to say reading and understanding the rules and scoring system would have really helped our team. We finished firmly last thanks to the majority of all laps across the team being penalties. In the words of my teammate Matt “Turns out we are both too quick and illiterate.” Another car had entered before us and already secured number 12 so i needed to clearly cross them out to avoid confusion for any other blue calsonic livery'd r32s at the event. The team consisted of an R32, an AE86, a supercharged V35, and a Kia CEED GT bought at salvage. I ensured we all had matching "Peer Pressure Racing" banners and overalls. This is the longest session of back to back hot laps the car has ever done (20mins no cool downs on a hot day).  It was a true test of the cooling /oil control mods and they certainly made big difference! Enjoy watching me lose 14 concurrent points for the team:  Unfortunately I only managed 45mins of track time over 3 sessions (20min, 20min, 5min) out of my allotted 90mins before my gearbox let go. Something related to shifter fork resulting in 3rd being neutral quickly followed by all gears neutral, then it being lock in two gears at once and unable to move. Optimistically there were no bad noises. But I am yet to pull box out and diagnose. Fortunately i was also to snag a tow home while I slapped a permit on the Kiaa which came on a trailer
    • Haha thanks for reply man Trying luck and Hoping to find one from all the sources, it's hard to find one as Nissan stopped production on sunroof glass panels
    • Great build man . I'm building RB30DET with CD009 gearbox aswell ,do you remember the length of driveshaft front of yoke to rear flange as I'm going for one piece. Thanks
    • Will all help with the for sale post when it's M3 time...
    • That sounds eerily familiar, I wodnder if he used the same.  Looks lovely.
