  • Replies 239
Yes i have also seen the black hummer. I tried overtaking him as he was doing 80kph on motorway, as soon as i tried his blue and red lights came on. I pulled over and he kept going. I dropped a picnic bar out my boxers! I was lucky, he may have got called away at the same moment. So be careful dudes!
wow, slightly off topic, but I have been out of the car scene for a year or two and just getting back into it again... god damn it must suck to be a P plater! Drivin with one of my mates little brothers today in his 33 non turbo pulled over 3 times between capalaba and ipswich rd by cops searchin for a turbo under the bonnet. Not quite sure half of them know what there looking at, one of them searched for a good 5 minutes for a turbo when it was plainly obvious it doesnt have one fromt he moment you open the bonnet. Anyways... happy to be on my opens :ninja:
spotted a newish light blue toyota landcruiser with a set of roof racks pulling someone over on the M1 near loganholme
plus my mate was pulled over by a green 180sx with all the lights in cleveland, he overtook them because they were doing 60 in an 80 zone. :mellow: scary stuff
Edited by 533EYA
Gateway motorway before Kuraby toll heading north.
Also a normal cop car can only do 170Klms at the max before they have to drop of because the lights cause too much drag in undercover cop cars not sure.
my uncle's a cop.
he told me that after 180km they have 2 stop, pull over for a couple of seconds, an turn off their lights.
because it's way to dangerous, some1 could b killed, and it would be the police's fault.
so i dunno wether it's tru or not, he's gotten a few things wrong b4.
i always try and prove him wrong lmao
my uncle's a cop.
Well I can only think of two ways to prove him right or wrong on that one, and at least one of them I wouldn't suggest lol
i could not see officer plod pulling over and waiting whist in pursuit
he has "raw emotion"
One of my Mates' Supra is supposed to be speed limited to 180.... "supposed to" and will/are are two separate terms.
Of course he only tests this on a track.......... :)
my uncle's a cop.
The only time I ever heard anything in relation to speed limited police vehicles were the old BMW motorbikes. They were not recommended to travel above 130 because of the saddle bag set up but that's complete bollocks about the cars.
When a pursuit is terminated police are pull to the side of the road and come to a complete stop. They are then supposed to carry out a test of equipment over the vehicle.
Police can do whatever speed they want but must justify their decisions should anything go wrong as they are always held accountable. Any pursuit where a police vehicle goes over 30kph above the speed limit must be investigated.
Hi guys, does anyone know if it is illegal to post pics of cop cars parked outside stations?
I was passing a station today and there was a few D cars parked, had my camera but didn't take any snaps. A pic is worth a thousand words.
I don't, however want to do anything against the law or rules here.
you have a right to take a pic of anything you want in this country
in china though.............
  • 3 weeks later...
Well i can confirm that undercover are aloud to go way over 170-180.. not revealing how i know that though :P
Well in my experience the com-co. controls the persuit. The lead car calls speed, traffic & road conditions in the interest of safety, for both the crew & the public (and offender) and the nearest available marked car is allocated the lead.
Most patrol & 'unmarked' cars are incapable of speeds much over 160kph, one reason is because the beads break loose on the tyres, so persuit cars are allocated the lead. Should the com-co. consider the the persuit 'dangerous', then the code 2 is called off or slowed down. Don't know of any 'checks' or 'investigations' unless a department vehicle has been damaged or an injury has taken place during a persuit.
A bit too much tv maybe..
But then what do I know.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
