It saves weight if you don't carry beer with you, buy it at the destination. My point is a modern medium/large suv makes a great tow bitch, way better dynamics, fuel economy and comfort compared with most ladder frame 4x4's. Particularly something with a V6 turbo diesel, struggling for power is a pain on a long trip..
Lol, what's this new trailer called, B Double?
Solar powered fridge is good, the lift pump battery on my trailer is charged by solar power which saves a lot of stuffing around on a trip.
Edited by 260DET
  • 5 months later...
I'm a towing newb.
Our 'big car' is a Mazda CX7. Be kind. Would you tow a car behind it?
That said, I think its only rated to 1700kg's braked, which doesn't leave much for a car considering the weight of the trailer. :(
 Not a great choice in my opinion mate. Even towing the R33 with my pretty heavy Ranger Ute I can feel it moving me around a bit on the road. A light little SUV like a CX7 would be dangerous in my opinion. A good gust of wind and you’ll be on the other side of the road!
The average car weighs around 1400-1500kgs so you’re right, it doesn’t leave much room for the weight of the trailer if the total is 1700kgs!
I'd do it one-off for slow and shorter trip, but not regularly. For a start most car trailers are 500-800kg so that means the car you are towing is limited to 900kg. And even then when you tow right up to the load limit you often learn that while the chassis can take the load, the engine won;t deliver the performance to tow it safely (hello creeping up hills on the freeway)
On 6/15/2018 at 10:40 AM, fatz said:
True
if your under 5’8 go defender
if you any taller you won’t fit
Or if you enjoy punching the underside of the dash with your knuckles ever time you put the handbrake down.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
