It saves weight if you don't carry beer with you, buy it at the destination. My point is a modern medium/large suv makes a great tow bitch, way better dynamics, fuel economy and comfort compared with most ladder frame 4x4's. Particularly something with a V6 turbo diesel, struggling for power is a pain on a long trip..
Lol, what's this new trailer called, B Double?
Solar powered fridge is good, the lift pump battery on my trailer is charged by solar power which saves a lot of stuffing around on a trip.
Edited by 260DET
  • 5 months later...
I'm a towing newb.
Our 'big car' is a Mazda CX7. Be kind. Would you tow a car behind it?
That said, I think its only rated to 1700kg's braked, which doesn't leave much for a car considering the weight of the trailer. :(
 Not a great choice in my opinion mate. Even towing the R33 with my pretty heavy Ranger Ute I can feel it moving me around a bit on the road. A light little SUV like a CX7 would be dangerous in my opinion. A good gust of wind and you’ll be on the other side of the road!
The average car weighs around 1400-1500kgs so you’re right, it doesn’t leave much room for the weight of the trailer if the total is 1700kgs!
I'd do it one-off for slow and shorter trip, but not regularly. For a start most car trailers are 500-800kg so that means the car you are towing is limited to 900kg. And even then when you tow right up to the load limit you often learn that while the chassis can take the load, the engine won;t deliver the performance to tow it safely (hello creeping up hills on the freeway)
On 6/15/2018 at 10:40 AM, fatz said:
True
if your under 5’8 go defender
if you any taller you won’t fit
Or if you enjoy punching the underside of the dash with your knuckles ever time you put the handbrake down.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
