Think I blocked Luke coming out of his work this arvo. If you were in the white landcruiser ute and couldnt get out coz of a prick in a silver Corolla.... My bad. Had had enough of bad ignorant drivers (not u) and was on a mission to get home.
I thought I spotted a stagea today, turned out to be a volvo
true story, I has a sad :(
Story of my life.
OT.
Spotted a maroon/red R33 driving through Robertson.
NFI what day.
Spotted GTR_N1 in a garage today :whistling:
and then a Gun Metal Grey 2 door R34 with GTR wing at Woolies parking at Cabramatta. Plates MZ_034 driven by a cute asian girl. If only I had my 34.. :action-smiley-069:
First R33 in continental Europe I have seen in 15 months... 2nd Skyline in that time as well, first was an R34 6 months ago.
München Deutschland.
White 34 GTR with plates MADGTR
Across the road from my best mates place.
Hills area, may also have a black or dark grey Ford Territory in the driveway (assuming they still own that car)? He's an SAU forum member, but we haven't seen him in here for ages.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
