Wow!
She sung about getting up in the morning, going to school and waiting for the weekend...
Then sung which day comes before and after each other...
Lyrical content = FAIL!
Was a good :laugh: though.
dont know how to break it to you man, but top gear is a TELEVISION SHOW!
it was designed to be commercial, an has been since episode 1. they have NEVER had any worthwhile technical info, and they never will as that wouldn't rate.
5th gear is even suckier. people who say it's the show for enthusiasts need their head examined.... it's just a second rate topgear, with an even more overtly gay presenter (although he is a much better driver)
and dont even start me on the other 2 homo's and the woman....
5th gear segments that dont involve tiff ALWAYS result in me changing the channel...
did you go see topgear live?
Their focus has changed from delivering car information to entertaining the general public with no knowledge of cars. When a woman or 10yr old kid say they enjoy watching Topgear you know that Topgear has lost the game. This was never the case a couple years ago. Proof of this is when ch9 purchased it because they saw the growing popularity amongst everyone, else it would have stayed on SBS as it has for many years.
Just watch any episodes from a couple years back, theres a reason why ch9 doesnt play any of the older episodes.
Unfortunately with all fads they will soon drop off. Gordon Ramsay, Bear Grylls and now Topgear. Look forward to 50% off Topgear merchandise at Target
I'd imagine their budget is ridiculously high, and without ratings they don't have shit. Technical info about cars that the audience can actually afford is boring as bat shit, which is exactly why it's not part of their show. Their tests and challenges are ridiculous for a reason, people enjoy watching that shit, which gives them the ratings and budget they need to keep going.
Just looked at 300rwkw R33 gtst (turbo is Blitz K5-660) goes pretty hard, in coming days I'll contact the mob who built it as the motor is forged (seen the receipts).
Noticed couple of things, there's a sensor on inlet pipe (next to BOV which is blocked) and pink label afm (it's R33 S2 and running on Power FC), hence my curiousity.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
