Thanks mate!
Ron: the SR is good for about that 280-300kw mark. Its just about control factors. If on 98 a little ping will do a lot of pop at that level, but if tuned safely (like on E85) they are pretty OK.
For reference my 'built motor' is nothing but a refreshed stocker with forged pistons. Im reusing the crank and rods and aiming for a motor that will never see more than 350 even if I do go crazy in the long run. It will probably never see over 300 in reality.
Because the last tune was close to 430 RWKW. Different head and a few different mods I wanna see what these little things can do. They should crack 450 without too much trouble.
-5's aren't too bad, A Z32 at Unique Autosports just cracked 447rwkw on 21psi and pump fuel with them.
are you saying someone nearly cracked 600rwhp with -5's at 21psi ??
From what he's said he has 3" Intakes on the turbos but they are run of the mill -5's apart from that.
http://www.aus300zx....2&postcount=358
Edited by Super Drager
Thanks mate!
Should go a td06sl2 20g 8 cm but with billet compressor wheels
Transistient boost response will be better and get maybe 10kw more up top
Hypergear can get them or gtpumps or you can get kando to make one as kamak is making billet compressor wheels now and kando get there turbos from them
I think you'll find they're 2871R's or -10's from my conversations with John from Uas who is building on it.
Could have misunderstood though.
Nope, take a look at the thread i posted. GT2860-5's. There is a Z32 that was built with GT2871R's though, he put down 467rwkw.
Have you seen any results of any of the above turbos vs billet wheeled versions?
my PT6262 .84 TS will be arriving this week hopefully, should in interesting. I havnt seen anyones results on this forum using one with this setup (25/30 with vct).. should be neck breakingly responsive ;), and if it taps out too early, well.. only $285 for the 1.0 housing to be sent to replace the 84 and try again.
Eagerly waiting results as this was the same path I wanted to go down! :) Built motor? Is the 6262 Gunna be pushed hard mate?
Just had a result sent in from a SR20det customer made 282rwkws. That is our billet version, don't want to hijack the thread, check out dyno readings on my thread.
I have a billet 7175 (.94 single entry) on a single cam rb30. With a powerglide.
It's as responsive if not slightly better than a 35r (1.0x). Makes 549hp@28psi on e85. Trapped 138mph. Keen to feed it proper boost soon and see how it goes :)
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
