not suprised, being auto...my 4294 with a .91 T6 housing wasn't any laggier than a 3540 1.06 on a RB30 single cammer really with a auto
only a split second was a 3540 better and then the 3540 got fiercely trodden on...
Edited by jet_r31
agreed that drag+auto = a totally different ball game when it comes to response. its got very little in common with response on a street or circuit car.
have had a 3076 on an old school 4 pot feel as responsive as a T25 SR with the right cam and stall combo. easy to do, just useless around a bend.
I had a 35r on a 6boost mani, I changed to a new 6boost mani and 7175, and it is more responsive In every way, makes more power earlier, power doesnt drop off, and builds boost on the tbrake significantly faster....
Must be moving on from older technology that did it...
Eagerly waiting results as this was the same path I wanted to go down! :) Built motor? Is the 6262 Gunna be pushed hard mate?
yea fully built 25/30, will be pushed hard eventually ;). Just dummy fitted the hot side tonight.
Uploaded with ImageShack.us
Edited by SilverECR33
Tossing up between a 6262, 6266 and 6466 on a stock capacity RB26... Looking for good response and 400-450rwkw on moderate boost 20-25psi
T4 0.82 divided rear... Want most of the boost all in by 4000rpm
Also is everyone just going journal bearing or running the ball bearing? I don't mind the extra cost if it's worth it
Well after Jez's result on his standard 26, it'll be hard to go past the 6262. He made 402 at just over 20 -21 psi IIRC.
I've seen some photos of the 66mm cea turbine next to their older stuff... I'd be highly tempted as the aero looks great.
Question in my mind is 62 vs 64 compressor in terms of lag. Id be tempted to just go a 6466 for the headroom, coz u know u will end up with a dirty 30 lol
When I was comparing my 6466 to a 6262 a few weeks ago, the angle on the blades looked a little different but also the gap between the blades on the intake were signicantly more of the 6466. Both were CEA's
Hmm thats indicating its more than just a change in trim, the 64mm comp must have a way bigger exducer than the 62mm so its more or less an entirely difference turbo.
Like comparing a 3076 and 3082 I guess. Same stuff, different application entirely.
A link to a page with comparison to old tech 65mm wheel (I think the 62mm turbine is same tech) and compared to new 66 CEA turbine:
http://realstreetperformance.com/store/precision-billet-cea-6266-turbo-750hp-turbocharger-2709.html?zenid=59df912a5cff403c6491d3cf5176bc7c
FYI both 6262 and 6266 are rated as 700HP items. I'd be chasing that 66 CEA item, better tech is where its at.
Finally got the 5558 in today, can I use any 3" v-band flange off ebay (exhaust/dump side), and what oil line/fitting did you guys use - do I just go to Pirtek/Enzed or get an ebay jobbie - re: Kando lines fit? I am not sure if you just connect the oil line to part way in the existing line or get rid of existing and new one straight to block? thanks :)
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
