Time to close the Varex.
Hehehe I'm with ya!
option 1 - Put a stocky on
option 2 - Steel wool! (dodgy, plus sparky ember things will fly out your hole on WOT...heheheh hole)
option 3 - get a custom legal exhaust made up
option 4 - i can't think of anymore options
Option 5, Varex damn you! Illegal though :P
My auto reviewer mate has a 480kw ve e2 walkinshaw ve at the moment. I just watched him take off before and i haven't heard a car that loud in quite some time. Once the valves in the exhaust open, you can hear this thing miles away.
This is a factory system, how will this car fair against operation pipedown?
Is it safe to say that the above mentioned car would be waved through without worries despite being signifiantly louder than the 90dB law?
There is no such thing as a Walkinshaw VE E2. He has a VE HSV E2 with a walkinshaw upgrade kit consisting of aftermarket parts.
Quote from the walkinshaw site:
"Few can claim to know Commodore and HSV cars like Walkinshaw Performance. Our range of products have been evaluated for their genuine contribution to improved performance and vehicle dynamics."
Therefore, if it is not the factory HSV exhaust, and its over the db limit, it is illegal plain and simple.
This is the upgrade kit you are talking about:
http://www.walkinshawperformance.com.au/wp...news.asp?ID=355
Yep that's the one. I apologise, i don't know a lot about commodores. In any case, unreal car, haven't heard anything like it.
is their any way of making the exhaust a bit quieter without those ugly silencers ???
you make an exhaust flange out of some steel sheet and drill a few holes in the center, then bolt it in and get an extra gasket flange for it.
you will have shit power same as a silencer after installing it
Tried the steel woool up the exhaust on my modded Ls1 powered VU Ute...... worked really well ( reduced the noise by about 15% I would say ) until........... the bloke doing the testing held it at the required revs and bits of wool started flying out .... one large chunk actually flew out and landed square on his microphone stand....... he was far from impressed.
The result a brief stint with a saussage muffler.
fkn classic! :D
YAY, now we can get rid of all these f**ktards with there fully sick cannons, an exhaust can be leagl and flow good power, no need to obnoxiously loud.
last time i heard the mic must be placed at a 90 degree angle to the exhaust and be 1-2 meters away, tell the f**ker to learn how to do his job.
I dont have a cannon either....in fact no muffler at all LOL.. :(
Now if only the damn truckies would turn those horrendous jake brakes off in my area...I'd be able to hear my own exhaust note. :(
jake brakes sound good in the tunnel, i only drive a merc rigid tho so its not loud, i do use it when i go through moe and morwell though just to try and wake the slack pricks up at 11am.
hahahaha :(
oh no you didnt.....................
say the M word :(
lol, i did, twice, im resisting the need to take moccies with me every day, the fact that i dont own any is helping the cause.
never drive on a sat night unless its close by
yer you got a point- but seriously if you need to go out you should be able to lol i reckon that over the next week just keep it low key until the "pipe down" is over. Plus if your exhaust is rediculous, well maybe you would get done regardless on which day of the week it is.
last year i got raped in the arse quite hard with my evo. Had 320kw at all fours with 44mm wastegate, screamer, td07 25g...the works. Epa hated me for life. Carbon emissions well...you dont wanna know heh. A lesson well learnt and a very very expensive one!
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
