Couldn't tell you who it was just a sale guy at justjap. The dampers are inside the coils so I imagine it makes piss all difference to rim clearance. Mounting would be the same I imagine. Call justjap to confirm though but I can't see it being much differece, if any.
The 8/6 are fine on the road for the R33, but it is a larger heavier car.I've got an ADM S15 and was thinking 4/4, 5/4 or something.
Not too such about having equal rate front and back mate.
You don't have much travel on the front as in the rear. You'd have to have the car pretty high (near stock) to not get it to slam on the tire when braking into a corner.
  • 3 weeks later...
hey guys i just put the BC's in my car - BR type on my 34 n/a coupe.
ive got them on the softest setting possible, and its great.
only problem is when the roads were wet yesterday after a long dry period, after turning a corner the tyres would loose traction under acceleration - even very lightly accelerating (i was driving granny spec, since i know roads tend to be quite slippery when it rains after a dry period)
is this somewhat normal? my car has never lost traction so badly or as much as yesterday in the 3 years ive had it so far
Did you lower the car when you put the coilovers in? This will mess up your alignment, which can give you traction issues
yeah the coilovers lowered it massively, it was on stock suspension before
thanks for that mate cleared it up well! I need to pop by bridgestone anyway, one of my studs broke when the wheels were being removed.
thanks again, glad its a somewhat easy fix!
big difference from stock suspension hey, i had some V1's installed set at about 8 from softest. havent lost traction yet (driving dry or wet) on some of the crappiest roads brisbane has to offer.
yeah its a huge difference, brings a smile to my face everytime i go for a drive still haha
thankfully its not too stiff, my kidneys are still intact! I was pretty worried about that.
Will be even better once i get my alignment sorted and the wheel nut fixed up :)
Ill get some pics up once i get time to detail my car ric :)
  • 1 month later...
  • 3 months later...
interesting thread there eightsixboy, thanks!
found this on there
the guy who posted this has since not replied, i wonder how its going for him lol
Couldn't get the link to work; what's the context behind the broken strut?
That would be the weakest part of the damper. I imagine it would happen to most thread adjustable dampers in a crash.
Quite possible; I'm more wondering if they're implying that the coilover breaking caused the car to crash, or this is what they found after a car crashed & decided it was the cause; rather than an effect.
  • 3 weeks later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
