I saw that in your car thread. Looks like it worked pretty well. Could you get enough force on it to tighten it?
Yeah - Barley. I just tightened it as much as I could, only needed it on the exhaust manifolds..so I guess i'll see in time.
I bought a set of these suckers the other day after I found a rounded out bolt (allen key type) working on the zed. Went to the local engineering store to buy an easy out and the guy talked me into grabbing one of these instead.
Worked really well, very easy to use. About $20 for a single bit (rather than $25 for a set of easy outs) but worked really well and no damage to the tool. I'm wondering where they have been all my life...
Edited by Rob260
that video is classic. can't help noticing it was a very soft bolt he was drilling in to.
good to hear it worked for you, might give one a try next time, a broken easy out is the world's most annoying problem, and it only ever happens where you can't get to it easily.
Haha yeah the video is awesome! You're right about the bolt in the vid though, takes a little longer to get through higher tensile bolts. Ignore all the "self centering" blah blah blah sales stuff though, definately have to centre punch when working with anything hard.
Another one that's come in handy lately -self tapping thread inserts.
Case hardened, Zinc plated steel. Very easy to use -the "kit" I bought from auto one had the insert threaded onto an M6 bolt, with a nut behind the insert. All you have to do is drill your guide hole, press the insert into the hole by applying pressure to the bolt and then wind the insert in using a 10mm spanner on the nut. Easy as and no special tools or kits required.
Looks like champion do a range of them too http://championpartsonline.com.au/index.php?route=product/product&product_id=23679
Interesting, wonder how those compare to a helicoil. Been a Helicoil'n nut since I bought the kit and doing all that work on the alum head.
Oh and did a little work with my new Ryobi multi tool in saw mode on some plastic. OMG where have you been all my life. Makes really quick work and you can really control the sawing action so well! Colour me impressed!
Hey that sounds good -might have to look into it! I prefer the thread insert to helicoil. Actually ended up using it where a helicoil had previously been used (not on a blind hole) and had somehow wound itself out the other side when removing the bolt. I didn't do the original repair so maybe it was a case of installation error.
These guys look good too http://www.timesert.com/html/install.html#A but more tooling involved
  • 3 weeks later...
Something for the fabricators out there.
A lot of guys ask how those swagged holes are done
The answer is a simple die tool.
It's a male and female die that are pressed together and forms the rolled edge seen on sheet metal work.
Not cheap tools but add that professional touch.
Wanted them for ages and finally got a set out of the USA a couple of weeks ago.
  • 3 months later...
I have these at work, they work great!
  • 1 month later...
Came across a .jp magazine about tools and comparisons, there was a brand that I hadn't come across before "Deen" . Ordered some and was massively surprised; just as good quality as Koken, Snap-on and Stahlwillie at half the price.
Where did you buy them from?
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
