How's this for cool tools? I got all this for $55 shipped to my door from HK. Gotta love sites like DealsExtreme. Take a while to ship stuff but uber cheap!
7pc Steel Dremmel Saw Blade Kit
4 piece Stainless Tweesers
3 different wool polishing tips (12 pces each)
6 piece dremmel Rotary File Kit
4 Titanium coated End Mills
and a MicroSD reader thrown in to boot!
On the topic of trolley jacks, a mate of mine has one that has a foot lever on it that you can use to get the pad up to the body, and lift it a bit, which is great if the jack is under the car a bit and you have bugger all movement with the handle.
As for cool tools, I can't think of much that I have. At least ones that are car related and not bike related. Something I plan on purchasing in the near future though is a split collet bearing removal kit.
Fellas, which websites would provide the best deals on Sidchrome/Kincrome items?
Am after a new socket set (a comprehensive one), an air compressor with rattle gun and a few other bits and bobs. Also need a bench top/table :)
Raj try VEK Tools in Smithfield - they always have a good selection in stock. Bunnings stock Kinchrome and Sidchrome too. If you are after a more comprehensive selection though, go with VEK. They are online. There is another VEK Tools in McGraths Hill if that is closer for you. If you are up for a drive there is Hawkesbury Toolworx in Nth Richmond - this one is a bit of a hidden gem, it is a small, but comprehensive, family owned tool shop.
Thanks Terry and Tim. Appreciate the heads up. Will definitely check out VEK - I have been hearing a lot about them.
I read about a few bargins that could be found online - a particular Sidchrome socket set at Repco had a price tag of $300+ and the same set was found online for $190 brand new! So I thought its better to ask around and seek the best deals before spending big dollars.
This drain plug socket is worth it's weight in gold!
very cool....where did you get it? I bought a whole bloody set to get one of those, would love to know where to get one on it's own
I use http://www.transquip.com.au/, good prices on kinchrome. But bunnings is hard to beat for one off items these days. They do guarantee lowest price
  • Like 1
I have to get one of those. Is this the one you got Eric?
DP1314 Teng Tools 13mm Square x 14mm Hex Drain Plug Socket
Is the idea that you then use a 14mm socket on the end to operate it? Dunno why they don't just use a half inch drive hole.
Thanks Eric. And Adam the one I have has 19mm hex on the other end, I've also got no idea why it's not just 1/2 square....I always forget and pick up a ratchet....
Rob I've got something similar and it's invaluable when putting engines back together for the initial checks. In one case it saved me a world of trouble shooting when it helped identify a tiny leak in the turbo water banjo.
Adam, yup that's the one. The hex body is 21mm and 14mm at the end. I need to get a 21mm spanner. I used an impact socket when I could reach, but the trans in the tunnel fowled the GTR front drive shaft. Grrr, had to use an adjustable spanner along side the drive shaft.
But still way better than rounding the insides with a 1/2 inch drive. Amazing how much that 0.5mm makes such a difference in torque.
  • 4 weeks later...
Looks good Duncan, still a bit pricey unless you where doing a lot of them each week, so I'll stick to the manual one for the moment.
I got a set of these http://www.machineryhouse.com.au/D108 the other day, they are really good for notching tube and hole cutting in thick section material.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
