Picked up some Sidchrome stubby ratcheting spanners and a 3 piece Ratchet set today.
Repco is having a 1/2 price clearance sale so cost me $49.99 for the ratchets (total) and $65 for the spanners.
My brother in law also bought a 64 piece socket set for $115.
Get in quick.
Edited by boxheadmr
Is this a good deal folks?
http://www.ebay.com.au/itm/SP-TOOLS-H-DUTY-TOOL-BOX-KIT-SPANNERS-SOCKETS-HAMMERS-PLIERS-SCREWDRIVERS-KC-/290682622113
Kinda need to spend money on tools, looks like I will save some cash in the long run as opposed to doing it piecemeal.
personally I would not buy a kit with AF tools, unless you use them for something. Try and find the same sort of size without the AF and save a bit.
I put together a set of the stuff I needed in EVA and its been great compared to having everything thrown in drawers loose.
BTW like Zeb said you may well find physical stores can match or better prices if you can pick up; they have good margins on those kits.
You want to be careful with the cheap stuff, ratchet handles and such tend to break.
Cheap sockets and spanners are fine as long as they are a good fit, you have to check how well the hex bit is shaped.
Maybe think about what tools you want to be good and what tools you can handle being cheap, then build up a set. I dont mind spending $100+ on a set of nice spanners.
And yeah af is useless unless you have some old or weird sht to fix.
A condensor for spraying at home. A copy of dads, his is much neater, mine works fine.
Bunnings copper pipe and air line fittings, Supercheap regulator/trap, plumbing shop brass fittings to adapt to the air fittings, and some bits from the junkpile to make a stand for it.
what other places can I try? what other brands do similar packages?
just work from their catalogue, and get a couple of quotes from local resellers. sp toolkits are here http://www.sptools.com/en/product-list-2014/tool-kits-en-2-3-4/#ty;pagination_contents;/en/product-list-2014/tool-kits-en-2-3-4/
most of my stuff is kincrome supplied by a local auto one, but you could also order them thru bunnings (lowest price guarantee). I'm not a tool brand whore but didn't want cheap either (broken tools cause ouchies).
No.
While they aren't going to be starwille or hazet
They aren't shit
Good to know.
Plenty of good tools are cheap, but knowing which ones is the trick.
I like Kinchrome level of quality, and some things i want nice i get Sidchrome. Snap-on and such prices are a joke.
  • 4 weeks later...
Ive never seen, nor would i want a ratchetting tap wrench. When cutting a thread you should be constantly turning it a bit backwards after a short cut forward just to make sure the metal doesnt tear and continues to cut
Ok thx -Irwin among others make them and there seem to be a few around on eBay etc (but obviously questionable quality). The ratchet mechanism seemed like it could be useful for tight spaces but I see what you mean.
Starrett T handle wrenches seem reasonably priced and plenty of good reviews. Might just grab one from Amazon.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
