Thanks Chris I'm very happy with it. Strange looking at that pic,,,looks like theres an abdormality in the fibre,,,a bit weird.
Yea Mat thats exactly where it's going. Mine was the test one and I have one more piece to do which is Duncan's dash and after that I'm going buy another sheet and do the Radicals dash.
Cheers
Neil.
That is what I need to mount my gauges on - please text me where you sourced the carbon fibre sheet from.
How are you going with wheel selection?
I have a few sets for my car but 18 x 8 with a 30 offset seems to provide good clearance and fills the R33 guards well.
Good old Jap wheels are a lot lighter and stronger that some of the new options that are going around and still affordable. You also have to think about spares as well so multiple sets would be in order. I have stuck with the old favourites of SSR, Enkie, Buddy Club, Nismo and OZ Racing for my collection in keeping with the R33 becoming a classic and look better with rims from the same era.
Charles,,,,I searched everywhere to find smaller pieces of carbon fibre and in the end the remote control boys at work had the answers.
Here's a link to one of them.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=230576472115&ssPageName=STRK:MEWAX:IT
I'm just about sold on 350Z wheels actually,,,while they are not the lightest,,,they are factory quality rims which I like and very cheap. I have my eye on a set on ebay so nobody bid on them please.
Cheers
Neil.
Cheers
Neil.
I've always thought the gauges down there were too far out of view for myself personally.
I used to have my boost gauge down there just above the ash tray, and the only way I knew what my boost was doing was to look at it... I much preferred them up higher.
How do you find the 5 gauges that Duncan has in the GTR sitting in that spot? Are they something you can "keep an eye on" easily?
Reason I ask is I'm still debating location for oil temp, water temp and oil pressure gauges for mine.
I think it's a very debatable question and I think ulimately you are right. While Duncan and my gauges are not in your straight line of sight,,,He and I are very awhere of them and so watch them constantly.
We both are using the turbosmart e-boost unit so that can sit on the steering shroud.
My gauge system will evolve over time,,,I will be still running my factory gauges,,,so they are sort of like idiot lights and this will be stage 1. Stage 2 will be to butcher a factory dash and insert as many of my stack gauges in there as possible. I'm also thinking about using the autometer shift light but without the tacho,,,like this,,,
http://www.ebay.com.au/itm/AUTO-METER-PRO-SHIFT-LITE-LIGHT-/200607885520?pt=AU_Car_Parts_Accessories&hash=item2eb52968d0
Stage 3 will a full race dash,,,be it stack/aim or my prefered option of motec.
Cheers
Neil.
Cheers
Neil.
Ah fair enough.
I think I'm going to end up hacking up a standard dash pretty soon. Mine still has road rego (Don't ask me why... LOL), so I'm thinking of ways to keep things functional, relatively legal, yet "raceable"
Na it still is well behaved.
It's sitting in the corner and doesn't give me any greif at all.......
I have done a few little maintainace bits to it
You should make it reliable and fit an LS1... I freamnof LS1 twin turbo with attessa...
You should make it reliable and fit an LS1... I dreamn of an LS1 twin turbo with attessa...
Oh the apprentice has spoken,,,. I beleive he also needs his mouth washed out with soap.
Brad is he helping or hindering,,,just don't let him any where near an engine with a heavy tool,,,,he thinks wacking things fixes it.
Cheers
Neil.
  • 1 month later...
  • 3 months later...
dammit where are the updates????
I heard this damn car is rewired, has cage, seats, belts, steering wheel, tow hooks, window nets, kill switches, checkerplate floors etc etc and is ready to run at the SAU day.
Any truth?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
