Blue is 98, Red is E85
This is with the 7psi springs so will be interesting to see if response picks up with a 14psi springs.
It's also with 272 cams, bigger than the general consensus on here...
Car has run 130mph with my big ass in it, so it makes the power no question.
It will.
It will start spooling earlier. Went from 7 to 15 psi spring and just ran it it off the gate to get base spring pressure and noticed the difference immediately.
What BW's would be recommended for a stock block - if you wanted to retain twins for rwc purposes?
They don't fit in stock locations. They're way too long.
This is what twins look like
AB1D3231-698F-4E76-9FD9-C49917044AE3_zps
C91700BF-E978-462A-B5F2-BD1063C7357B_zps
The smallest twin EFR's (6258's) will do 500 wkw on a well sorted setup. Brightey who posted above has a set on his RB28.
Forget the 0.92. 1.05. Better setup for when you realise the 7670 is too small :D
7670 would be great on RB25, but on RB26 i think too small for anything other than bone stock engine for autox events imo. Maybe if you were limited to low boosthe or wanted to keep revs down for some reason?
Single EFR for the "-7/-9 on a stock engine" type of build.
How does it compare to the TO4Z you drive a while back?
Speaking to a local turbo guy and he said he can mod a Zed to bring it on 800rpm earlier, make more powa, and improve the already good part throttle transient response. Not sure if its an exaggeration, but interested to hear ur thoughts.
He also mentioned these EFRs and SXEs are very very good.
[emoji2] [emoji2] [emoji2]
Id hazard a guess he'd just throw away old comp wheel and fit the ebay gtx style billet 11 blader that everybody uses?
My mechanic has a EFR 8374 on his built RB26
Made 550kw on e85 on 32-30psi
has 32psi by 4200rpm
i'll see if he'll let me put his dyno graph on here... havent been in it yet but response looks mental
i've also bought an EFR 8374.... mine should be getting overhauled in July hopefully
stock bottom end EFR 8374.... see how we go
  • Like 1
Pretty much. I think they machine the housing and put bigger wheels in them. I will find out tomorrow.
Yeah that E85 is tempting me as well.
I totally believe the 32 psi by 4200 with anywhere near a decent tune on E85.
It's funny how this turbo comes on. It will make the 10 psi on bottom end while cruising and slow spooling, but right around 3800-4k the turbo turns on. I can't wait to get mine to a solid 20 psi on pump. I can NOT imagine what 32 psi on E85 feels like!
  • Like 1
I just don't really want 500+kW, so why go bigger? More momentum etc with the bigger wheel is my logic
You should run it through matchbot, you will hit the right side wall and it will overspeed .
I have tried countless configurations on match bot and rb26/28. The efr 8374 .92 is what I have, but if I could get e85 ( none in Nippon) then I would go 1.05 and wind it up.
I've seen the light haaaaaaa!
Edited by Meathead
  • Like 3
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
