Just found my v35 rims sitting on the doorstep in plain view of the who street, good one stupid courier driver.
just test fitted them and for some reason i dont think i will need spacers on the rear which makes no sense because my 17 x 8 35 offset would not
fit but the 18 x 8 30 offset does ?????????? its only 5mm difference mind you i havent put any rubber on them yet but only been 235 they wont over hang so we will have to
wait and see what happens.
And the the rims arn't in as good condition as i thought they would be, so i might have to give them a cut and polish or re painted.
they look bloody tough and i cant wait to get every thing sorted.
nope
Can you get that stuff in gold....that way it will go with the yellow and you wont see it :happy:
gold would actualy be better because its better at reflecting heat than silver (hence why a mclaren has a gold lined engine bay)
like i said, it doesn't look fancy but you can feel the difference in temperature inside the foam to outside and also quetens down the spool noise a bit too
Got my car back, nice and fixed :P
Also just put a deposit on one of the last 24U blocks made: brand new, and still wrapped: let the engine build begin!!
not going Rb30. . . . disappointed Micah
There is a nice RRR rb26 block on yahoo. . . big $$ thuo
RB26 is what my old man had in the car: RB26 is how I have to keep it - if not for sentimentality, I'd be looking at 3L immediately. With correctly matched turbo and better management, I'm confident it will be what I want it to... Besides, I got the N1 block for a steal!
If you want to keeps yours on the road, I will have a spare rb26 head to sell soon.
N1 block should be sweet. What turbos you going to run?
I just spent 2.5 days polishing mine. Far out, these cars are waaaay too big to polish. Looks great now. Ended up hitting the small scratches with Meguires Scratch X, then did the whole thing with Mother's Clay Bar and then Meguires Gold Class, then Mother's Back to Black on the roof racks and other black bits. Far out what a day!! Kinda ran out of time to do the windows and then take photos before the sun went down :(
My wideband AFR meter arrived today at 3pm, but I had no time to fit it :wub: Back to work tomorrow for 2 weeks, so it'll have to wait a while :wub:
Tried the unique auto sports brake upgrade on the s2 this week . I have to say they do not work on stags . Looking at making my own kit . This will be able to use 324mm disc and the sumitomo 4 pots . Direct bolt on no mods . Have to check on brake lines once on car . Will be out to see a "CAD" man tomorrow . Looking at two different set ups maybe 330mm will fit aswell . Will keep all posted.
booking the car in with chequered tuning (status)to put a nistune in tomorrow should be done by the end of the month as there busy so will have the extra killawasps just in time for deca
very surprised it didn't fit - every skyline brake bit I've put on mine bolted straight on....I've run gtr front and rear brakes on it now?
what was the problem, did the adapter hit on something? Either way Im sure UAS will refund.
+1 on this....I fitted 324mm rotors using R32 GTR callipers with the brackets they supplied me with only a slight mod.
Had a busy week
New front and rear brake disc, pads, braided lines and rebuilt r34 calipers and painted in 2pac
Engine covers painted in 2pac
Greddy copy inlet manifold
650cc injectors and new fuel rail and Sard FPR
Z32 AFM
Fuel pump 13.2V direct feed
New alloy radiator
Next week
GTR BOV
Mod intercooler piping and exhaust
Tune Nistune ecu
Re-assembly front end of car
When time premits parts waiting to go in
Defi 3 DIN gauges
Evo 8 recaro's
GTR front sway bar
Adj caster and camber arms and bushes
Minor stereo upgrade
looking at a decent sized single: T04/GT35 or similar with a modified head, single throttle body and mildish cams: I am gunning for midrange, and don't really car what the peak output ends up being as long as it's responsive...
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
