Hey, I drove mine today. Keep getting 13+ psi then the BOV goes. Hope to get some good brains next weekend at the cruise to sort this.
And actually the car goes great apart from this little glich.
do you mean to boost up that high hugh? or is it spiking or creeping that high. i found my stock bov kept blowing open as soon as i hit about 14psi after my turbo upgrade, i don't think they are really designed to hold much more than stock pressures.
Mine copped a bit of coin leading up to the QLD meet... :banana:
Profec EBC
Dump Pipe
Front Pipe
High Flow Cat
Rear Camber Arms
Rear Toe Arms
Cooler Piping
Cold Air Induction
Rear Calipers + Pads + Rotors
Nistune Board + Partial tune
Mounted the Defi guages properly
Getting new tires this Thursday...
Best of all... I washed it :)
Almost forgot.. I picked up some Personalised Plates :P
Mowing your lawns?? :banana:
haha, let us know how you go :)
Well AEM AFR gauge is in though I haven't finished the dash mounting because barbecue and beer were calling. I'll put everyting back in tomorrow.
I had welded the boss in the exhaust just after the decat because I noticed a nicely placed grommet in the floor there which lines up under the passenger seat for the wiring to go through.
Is the Nismo ECU any good though or is it another raised rev limit, more timing and buckets more fuel? I am asking Kristian to bid on an M35 for me this week!
Apparently the Nismo ECU is a standard pre-tune program you buy from the shop....no dyno tune to you car needed.....plug and play. From memory it’s got the speed limiter lifted to 250km’s, snow is eco, better throttle response and a slight boost increase, increased rev limit + tune.
but then again all the above is not 100%....I guess I wont find out until next week......the one thing I am after is more RPM and better throttle response.
good luck finding one......a little birdie told me about this one....there as pretty hard to find......this is only the second on I have had the chance to bid on!
Can the 'tune' be extracted or do we all have to wait for the SAS guys to do their stuff? I have been reading the forums for the past couple of months and the ecu seems to be where the power is lost, so it's the place to look for some decent gains. Forgive my ignorance but what's so hard about getting the ecu re-flashed? Not that anyone in TAssie would do it but I would like to send mine off and get it done.
it's Nismo!.......will post more info when I get it!
I just cannot wait to get the Haltech off! :banana:
I have never ever seen a haltech but wonder why or how it is not working on your car. What problems are you experiencing?
The Nismo sounds like a punt. How much is sh*tloads of money?
If you have $2000 and wiring skills a proven ecu is the Link (or ViPec if you prefer) wire-in version. The 2wd manual M35 for sale on TradeMe found the Link to be the best way to provide tuning capability on the V6 engine.
i'm pretty sure the stock ecu does all the shifting too so i dont know how much of a solution a link would be
heard a lot of ppl raving about adaptronic too
but again, what do you do for auto box control?
With a wire in Link you can pick and choose the functions you want the Link to take over (e.g. all the engine management functions) and if the auto computer is inside the stock ecu leave it there to do all the auto functions. The Link's "flat change" ability should take care of the old problem of undue shocks during gear changes.
(ps the change to a map system will get rid of problems with the stock afm)
Its all an unknown though, as nobody has done it yet. Even a simple emanage install on mine has taken over 100 power runs to get to run smoothly.
The transmission has a separate controller which communicates with the ecu to back off the accelerator and timing for gear changes, it will still shift without this communication but the box cant handle it.
Believe me, I would love to get standalone control of the engine but I don't have 5 grand to blow on unit, fitting and tune, only to find the p1ggyback does just as good a job. I believe there are at least 10 owners waiting for the reflash (myself included) due to the illegal aspect of these aftermarket ecu's.
basically what Scottynm35 said!
My reasoning for getting the Nismo btw is not because I have given up on SAS.....but is so SAS can a least get a close tune to it....all things being good with the Nismo that is.
@KiwiRST4 Haltech....don't get me started :ninja: ......let's just put it this way....I am sure for some cars they are brilliant(e.g R35 GTR)....but for ours give it a miss.
The only way to truly control this motor is through a standalone ECU or a reflash.....piggybacks will not do it....sorry most piggybacks(theres one but it's about $2K) will not do it.
p.s. A standalone will not work unless you manualise the gearbox.
Edited by Jetwreck
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
