simon the top half was removed when i drilled it pinch.gif. had the manifold welded before you post regarding the splitter and how it would completely disrupt the flow and end up being worse of. the damage was done so i thought id throw it on any way. on the standard turbo it was fine, but not too sure how it would be pushing 20psi. It will probably crack any way as the boys were saying, ill just get the gate welded to rear housing worse comes to worst
Or weld to the turbine housing, much easier and cheaper to fix if something fails. :thumbsup:
Its a pity the new ebay stainless T3 GT30 rears dont bolt up to the Kando's, that way the bend and flange are all similar metals to the housing. Perhaps its worth machining one out a few mm?
im keen on finding out about a t67 on rb25det with 98 pump fuel as here in wait awhile we dont have e85 yet. and i really cannot be bothered ordering and running the risk of running out of fuel somewhere unless simon has a better idea on how to get around this little problem haha
Mate STATUS has posted a few results of people running the T67 on 98...
There was even a guy who posted his results through an auto and low boost, it still make like 270kw....
STATUS has posted results of people on 98 doing about 330kw, should be good for the same on others Id say.
Thanks Scott, clearly i've missed those in my reading. I'll re-attack the posts. :thumbsup:
Just a quick question, ive got my bday coming up soon and my bro' s and sisters asked me what i wanted. I said a turbo lol. There willing to all chuck in some money towards a kando TD06H - 18G internal gate with a 0.5 bar actuator. So do u think this turbo would suit a 4cyl 1.8L engine ?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Cover-T3-8cm-V-Band-Housing-TD06H-20G-/290664105318?pt=AU_Car_Parts_Accessories&hash=item43acee4566#ht_2744wt_1396
This one states a 20G wheel but they should be able to change it for an 18G for the same price. What do yous think ?
Are you taking the piss or being serious? :thumbsup: I dont care but you could be right. Perhaps the smaller exhaust pulses of the pissy little 2L six means things are a little more sensitive to exhaust flow and back pressure
I was joking lol
cheers gtscott i missed it also ill have to wait for e85 over here in wait awhile (wa)
http://www.ebay.com....#ht_2744wt_1396
Was that a typo mate? TD06H-18g is overkill.
Had you meant TD05H-18g in an internal gate form with T25 SR20 style housing, then go for it :thumbsup: ive done one of those myself and it was a really nice turbo.
And to the others, no worries. I more or less check this thread daily so I have a fairly good recollection of what weve discussed or what has come up over the time. Its just about my favourite thread lol.
I had my doubts that a TD06 would have been a lil big. Thats why i wanted a 2nd opinion, so u think the below option would be better. It will be on a T3 flange manifold not a T25
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-TD05H-18G-w-T3-8cm-V-Band-Internal-Gated-Housing-/270918417854?_trksid=p3286.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D6453559929143493497#ht_2730wt_1396
I dont have ebay access at work so Ill need to update this from home.
What motor is it? Is there a reason you are limited to a T3 flange? The T3 IWG housings are highly undesirable.
Whilst the gate looks great mounted there im worried it will crack eventually. Isnt that the weak point where the manifolds crack without cutting a 2 inch hole?
I think you are well on your way to the 300 club. :thumbsup:
maybe even mid 300's now its on wild the sphincter of the universe
lol
i wrote wild t u r k ey and i get sphincter of the universe wtf?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
