I know, for me music is as good as manditory when driving. I'm lucky my trip to work is only 15min, if it was like an hour i think I'd go crazy. I already find myself humming along with the tone of the exhaust note lol
haha thats not as bad as me.
when i crashed one of my S15s i was driving a FWD pintara, i was making turbo and BOV sounds when i was driving it. no, the radio also didnt work in that car :(
No mate, sadly my finances don't run to Brembo's unfortunately, but I think the R33GTSt calipers teamed with this;
http://www.conceptzp...40203.166.28.81
I should have more than enough brake power.:thumbsup:
yup thats the kit Ive got on the front of my S1 stag
r32 gtst calipers tho for me
Interested to hear how you get on with these brackets. I have tried several on my C34 without being able to fit them (very different from Skylines) although I see you have an M35 - lets hope they are the same as 350Z.
mate no worries with the brackets, fit fine on my S1
also the bracket set from revolution brakes Wilwood superlite 4-pot / 324mm discs fit fine too !
Fitted a brand new bright red Recaro millinium to the drivers side. passenger side can wait to see if I like the fit.
Picked up a pair of new Drift seats (r34 GTR copies) today as well in black
Cleaned up the the EVO 8 recaros as well today
Need to decide which seats to use.
Also looking at some new Bride Euro II as well later this week. similar to GTR
Measured up some new 6 pot 355mm brakes today for the front to see if they will fit behind the 19" GT-c's
Today i chucked in some splitfires because three of the stockers were missing at high revs in third gear.
I also installed an AVH-3200BT double din reciever awesome unit for the price, now i've just gotta find time to put the amp in!
Put some Works Meisters on...
Very nice man, surprisingly good actually!
You got that cooler in yet?
nice!!!
now you just need aero side skirts and rear bar to match the front bar :)
LOL... maybe you need to drop a less subtle hint!
Thanks for the positive comments fellas.
I never thought my front bar was anything other than stock standard. What do the Aero sides and rear bar look like?
Haven't got the cooler in yet, but that's going in once the car's out of the bodyshop.
That, and a tune are my main priorities because the car won't rev beyond 2300rpm right now sad.gif
A tune wont help you, sounds like the afm is cactus. What are the symtoms, do you have an engine light?
Don't pay people to fix these barges whatever you do. They will take you for a ride every time as they most likely have no idea when it comes to fault finding M35's. Use the good SAU resource, us blokes, and fix it yourself. :thumbsup:
  • Like 1
Can I have a stab and say limp mode from a stuffed AFM?
Gotta play the odds :P
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
