I know, for me music is as good as manditory when driving. I'm lucky my trip to work is only 15min, if it was like an hour i think I'd go crazy. I already find myself humming along with the tone of the exhaust note lol
haha thats not as bad as me.
when i crashed one of my S15s i was driving a FWD pintara, i was making turbo and BOV sounds when i was driving it. no, the radio also didnt work in that car :(
No mate, sadly my finances don't run to Brembo's unfortunately, but I think the R33GTSt calipers teamed with this;
http://www.conceptzp...40203.166.28.81
I should have more than enough brake power.:thumbsup:
yup thats the kit Ive got on the front of my S1 stag
r32 gtst calipers tho for me
Interested to hear how you get on with these brackets. I have tried several on my C34 without being able to fit them (very different from Skylines) although I see you have an M35 - lets hope they are the same as 350Z.
mate no worries with the brackets, fit fine on my S1
also the bracket set from revolution brakes Wilwood superlite 4-pot / 324mm discs fit fine too !
Fitted a brand new bright red Recaro millinium to the drivers side. passenger side can wait to see if I like the fit.
Picked up a pair of new Drift seats (r34 GTR copies) today as well in black
Cleaned up the the EVO 8 recaros as well today
Need to decide which seats to use.
Also looking at some new Bride Euro II as well later this week. similar to GTR
Measured up some new 6 pot 355mm brakes today for the front to see if they will fit behind the 19" GT-c's
Today i chucked in some splitfires because three of the stockers were missing at high revs in third gear.
I also installed an AVH-3200BT double din reciever awesome unit for the price, now i've just gotta find time to put the amp in!
Put some Works Meisters on...
Very nice man, surprisingly good actually!
You got that cooler in yet?
nice!!!
now you just need aero side skirts and rear bar to match the front bar :)
LOL... maybe you need to drop a less subtle hint!
Thanks for the positive comments fellas.
I never thought my front bar was anything other than stock standard. What do the Aero sides and rear bar look like?
Haven't got the cooler in yet, but that's going in once the car's out of the bodyshop.
That, and a tune are my main priorities because the car won't rev beyond 2300rpm right now sad.gif
A tune wont help you, sounds like the afm is cactus. What are the symtoms, do you have an engine light?
Don't pay people to fix these barges whatever you do. They will take you for a ride every time as they most likely have no idea when it comes to fault finding M35's. Use the good SAU resource, us blokes, and fix it yourself. :thumbsup:
  • Like 1
Can I have a stab and say limp mode from a stuffed AFM?
Gotta play the odds :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
