What's the benefit of the shift kit? (ie. what does he change, and can you ask for particular performance/snappier gear changes etc.?)
it applys more pressure to the clutch plates quicker so it eliminates slipping depenind on the power you chase.
the gears become more snappier and wont heat up as much causing a 3k + rebuild.
It should also lengthen the life of your gear box
it applys more pressure to the clutch plates quicker so it eliminates slipping depending on the power you chasing.
The all important part of the sentence!
My GB don't like shift ATM!
Today gave the 25G to my son. Yippieeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. He has his Ps. I can now sleep late and drink more.
Nice mate
congratulations in order to the young buck
now, hope he's saving and throws on a turbo, or two, behind your back :nyaanyaa:
I wouldnt say there'll be a warranty unless they're installing it, and like scott says a couple of springs.. but i'll ask n give you a buzz later.
Trans Go shift kit install CLICK HERE
Scott - that's what I was talking about last night.
Thanks guys. I have started already.Got turbo and turbo back and mannifold. Fuel pump and 370 injectors and ecu and AFM. Will go fmic and Greddy FF plenum. Still lots of bits to get but have plenty of time.
Funny thing is he drove the RS4 for the last time when he did the test. A bit ironic.
Hi all i have done the steel fiting out of the back of the thermostat housing mount ! What apain in the rs . But while i was that far in did the timing belt and the bearings that go with it. All the other belts that go with it.
Wooooohoooo. Fixed that stupid farting sound tonight. Visited Kyle who had a spare stock bov and we put it on. No more boost leakage!!!
Talking about gearbox...he actually mentioned his goal was to mate a r34 manual box to his arx...
I would say it is, glad im not the only one in that position. We have some work ahead of us...
BANG! N the turbo has now died.. For the second time lol. Biiiiiiigggggerrr turbo now. So I think I win, I know have more work than u lol
Crap Aaron. What have you done to your car to deserve that? I'm interested so I might be able to keep mine running longer....
I do like your positive attitude though. Spoken like a young person with no kids/mortgage and plenty of time to devote to their car :)
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
