Ripped Aaron's turbo out, 2 hours flat. Not bad going.
He is going for a bush core this time as bearings have left a bad taste in his exhaust, and bits of wheel. Shaft snapped in half.
Don't want to sound sceptical, but can you prove the increase in driveability, economy and reduction of intake temps?
This argument has been done to death.:whistling:
Back to back, same day, plenum skin temp measured with a non contact temp gun (accurate to 800deg) 31deg reduction.
Economy; only .1-.2 km/l, possibly a bit more.
Driveability; VERY subjective, because it's a "seat of the pants thing". But; Yes, farking HEAPS! Better response, stacks more torque.
DUDE! i have to give scott the biggest props for doing this!! had the turbo out in 2 hours! and managed to get it fixed under warranty..
stage 2 wheels bush bearing core!
cant wait now.
8psi. lol. Not even tuned, second gear apparently at 2000 revs. The bearings were noisy when it first went in, after 3 months it had snapped the shaft and demolished the exhaust wheel, front looked pretty good considering but it was seized.
I had the car on stands, its an easy job if there is no heat-shield so guess what's not going back on. lol. 3m stick-on heat-shield will do the job nicely. :thumbsup:
yeh 2nd gear at about 2k revs. i was behind someone going slow so i wasnt even pushing it.. i mean it was 6am.. i was tired. then bang black smoke. that woke me up good.
hasnt been in the car for even half a year..
n yeh ive turned the boost right down as it wasnt tuned yet..
I don't really want to dob the shop in as he is looking after us with a warranty, it was a ball bearing highflow though.
Due to the damage to the housings it looks like he is going bigger than mine.
Nice, how do you plan to get it running?
I still think its a downgrade unless you go forged internals...
You are suffocating the engine if that has the stock turbo on it. You will be on boost at idle. lol.
The engine will be built, and it will run a bigger turbo.
Firstly though, I need to sort out the EMS and get a manual conversion happening. My tuner tried on the Haltech and said it isn't compatible, something to do with the pulses, I forget what exactly.
Has anyone made any headway in manual conversions for the M35?
Is the R34 GTR gearbox with bellhousing modifications the go?
Im about to go down this path myself but I think I will hold off on my 3.5 build for now for the very reason you are having now, people dont understand these engines. You will have to go standalone, PS2000 or motec m800 or similar which means you may not have the dash, attessa abs etc. Will you be paying a mechanic to learn all about this engine?
Pulses? I guess he means the crank sensor? Better find a new tuner... What Haltech was he using anyway?
What prompted this change over? Did you damage your engine? Do you still have it?
lol... you don't sound sceptical at all!
Point taken. I have just been on a few forums where people fit stuff, then say how good it is without hard data. I can't really 'feel' your 'seat of the pants' performance upgrade.
Just want numbers that's all.
Thanks Daleo.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
