this is the connector for the atessa bleeding in a c34 (unplug it and it will run the motor continiously )
Looks like we have something similar, found this in the workshop manuals..
With the rough translation from Google being
3. The key switch to ON state without starting the engine.
4. Remove the connector for the driver side Insutoroa of bleeding.
Been cut off by removing the wire connector •, entering into an air bleeding.
The motor drives the pump at the same time, stopping after a few seconds. In this state
Constant pressure causes the actuator transfer
  • Nope 1
will have a look at that this arvo!
Those workshop manuals come in handy. Hopefully the plug taped into the OBD2 loom has the answer. You would never know about it otherwise.
Let me know how you go Craig, I will do mine too.
and me!
Well it does run the pumP....just need to get motivated and bleed it now.
So that's what that does (just tested it). I unplugged mine when chasing to see why my infometer wouldn't work and it threw up a 4WD light. I never unplugged it with the ignition on tho. It looks so aftermarket & not factory at all, unless my connector is different. In the end I had to take a wire from this connector & feed it back into the ODBII plug to allow the infometer to pick up the CAN signal, so mine must have been changed at some stage. Nice find, thanks.
I don't know if m35 is the same as r32/r33/r34. But if it is:
You will not loose xfer case oil if you drop the front driveshaft. There is a seal
The system will always bleed when the motor is running. Once the accumulator is empty the pump will start up.
There is a second bleeder just above the rear driveshaft (in addition to the one at the gearbox). 9 times out of 10 you don't need to use it, perhaps this is the 1 time.
Decided to smash out my fog lights [ stagea s 2 ] a bit of a hard job to break into bits and get out .Looks heaps better
I did this a while ago, thought I got all the pieces out, then after a few weeks of driving I notice some little bits of yellow glass still in there lol
Can you see what happens if you unplug that plug, start the car and then push the brake pedal 5 times? (if Nissan were nice, it should go in to 2WD mode!)
  • Like 1
As soon as you start driving the 4wd light comes on, looks like it works just fine. I dont know if I would trust this method on the dyno unfortunately. If the pressure ever came back on it would be interesting to say the least...
Have you bled yours yet Craig?
if its as easy as that to disable. im rigging up a switch :)
Iain i did it to mine, it doesnt feel to good after abit of driving in 2WD. the car seems to vibrate in park, or idle.
i plugged it back up to see a difference, and it wasnt vibrating after a drive...
I thought the torque feels better in 4wd, cant explain it, but i think i liked 4WD better.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
