buy a commo.... single wheel skids is obviously your thing. :nyaanyaa:
Or spend the 1k on a LSD and make Jetwreck jealous!
Dropped exhaust in today to get a few more inches- My measuring sucks. Has anyone with a NM35 found if the V35 coupe midepipe fits...? larger pipe, single resonator and CHEAP!
Edited by PN-Mad
Built myself a polycarbonate air box to go around pods, I've got air coming in from inner guard, behind head light + i've kept the factory snorkle coming in the top.
Intake air temp has dropped about 7 deg on average.
As soon as you start driving the 4wd light comes on, looks like it works just fine. I dont know if I would trust this method on the dyno unfortunately. If the pressure ever came back on it would be interesting to say the least...
Have you bled yours yet Craig?
In C34's a solid light (should start flashing after you've pushed the brake pedal 5 times) coming on when you start moving is an error.. be careful as if you've unplugged the plug and have a solid 4WD light (at least in C34's) you're in full 50/50.
thats what i thought. tried spinning the wheels up on gravel and didnt kick out with 230kw. i think i may have gotten all foour spinning though.
does the car have to be in ignition, or running when you press the pedal 5 times..?
this doesn't work Aaron...pity too!..........if you want 2WD just unplug the front ABS plug's going to the sensors....easiest way and it work's.ph34r.gif
PS. Your car will still not wheel spin from stop even with 2WD....it may or may not break traction when it comes on boost depending on road surface......It's 2t, auto, 2.5lt, has dumb arse TB restrictions and long diff ratio's!
Edited by Jetwreck
i figured, i guess the 4WD light on means permanent 4WD, just get the f**ker checked lol
is unplugging the ABS safe? as in i kno it will instead skid to a stop, but driving around like this is safe?
pictures on how to do it.. lol just to see.
lol......once upon a time there was not ABS!thumbsup.gif....ABS was invented for people who don't know how to brake!...I don't think I have used it in an emergency even though I know I have it!.....in fact if you brake on a dirt road you are better off not using ABS as you can stop better without it....if you know how to use a brake that is!nyaanyaa.gif
picture on how to do what....a burnout!....lol!
  • Like 2
THIS
I reckon EVERYONE should learn how to drive and have to take the driving test (which should include an "advanced driving" course) in a pre-1985, manual car.
  • Like 1
THIS
Totally agree....more to the point I think Insurance company's should have a discount scheme for those who choose to do those courses!
  • Like 1
THIS
I'm alright. I'd take the Datto. :D Stops better repeatedly than most modern cars :whistling:
+11ty to all the braking comments above.
As for 4WD>2WD, car has to be started, it will work if you just turn the key to ON but resets when you start the engine so you have to pump the brake pedal again. If successful the 4WD light should come on and start flashing.
As Jetwreck said above, it's not going to light up standing on it from stationary (hopefully it will when I get my 3L bottom end in :D) but from about 4000rpm with VCT engaged it lights up, 5000rpm without VCT. Sit it on the brake, wheels start turning at about 2500rpm, slowly climbs to 3000rpm where it starts to build some boost, about 3500rpm it's making significant boost and skyrockets to the limiter.. bounce limiter once or twice and click 2nd, release brake, super fun happy strips time!
NOTE: this is from C34 experience, but seeing as how Nissan like to not recreate the wheel so to speak, I'd be interested to see if it is the same for M35 and would be surprised if it's not :)
  • Like 1
Going to be adding a bit of oil capacity & trying an interesting budget brake upgrade...
Edited by Daleo
Cool. Interested in the reasoning behind going with the oil pan spacer instead of an oil cooler?
It was cheap & simple.
I can't really justify the expense of a cooler setup with an oil thermostat, and that's the only way I'm prepared to do it; so more oil+deeper sump is a win for me right now.
That and it was a box filler for my brake brackets...
Edited by Daleo
These spacers have the fitting for oil temp right? I wanted to get one too but wasn't 100% it would fit. (plus I really should make my own.) :)
This one doesn't, but I'm only a threaded hole away. The one that did have it was another $30.
I'm about to find out if it'll fit, if not I'm sure a V series owner will take it off my hands.
Edited by Daleo
Probably, as long as you can find a mechanic to fit it for them :P
Waiting with baited breath for the results of the adapters!
So I might be able to make some more money fitting it for them?whistling.gif
Me too Andy, roll on weekend for the mock up!
Lets see how good my measuring is... Only other issue I can think of, is that the rotor radius may not fit fully inside the caliper.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
