I dropped and changed the oil in both diff's
the oil that came out was putrid and like it had turned to water. glad i did it.
also got scotty to make me up a new "pre throttle body" IC pipe (the one with the BOV attached to it.) Have a look. gonna get some 3m sticky heat shield and cover it up. should look good
Easy to drop the oil in the diffs?
Me thinks a Tutorial is a good idea :D
good idea. might write one up on the m35info forum if the mod's want?
took me 20 minutes each diff + the time it would take to take the tray(rock deflector thing) off the front
you need a 1mm Allen key 3 quarts of diff fluid - should take two and abit.
same as servicing the transfer case.. drain with bottom allen key bolt, close up. fill with top allen key bolt until it overflows. pretty simple honestly.
dont know if u notice a difference in drive, but gives you piece of mind knowing you've done it.
I think if you come from S.Africa, its called a Ellen key.... (saw it written on a S.Africans toolbox - lol)
Anyways Going to strip, clean, and re-set the Throttle body this weekend. Any tips?
I got the reset idle air volume instructions etc etc... anything else i should know, what to touch/ what not to touch?
also interested. i cleaned the visible part last night. now warm idle is 750ish RPM
oops.
can it be reset?
Depends. Not on my original one it couldn't.... unless Iain has somehow managed it.
I think I may have stretched whatever is in there because my warm idle was just over 1100rpm (cold was around the 1600rpm mark)
Edited by iamhe77
650 +/- 50rpm is factory spec, so 750 shouldn't be an issue.
Mine idles 550-650 (500 when hot). No issues at all.
Guess it just comes down to how comfortable you are with it.
yeh. if i come accross a second hand one, i'l grab it and fix it. but i think it will be on the 'when i can be bothered' list
why not clean and re-set the idle...?
Nothing to stretch in there - its only cogs/motors/sensors afaik
mine is about 750 at the moment in N or P, about 700 in D.
Did the other shopping trolly (that has done 175k Kms) today, cleaned TB and MAF, good result -idles much smoother now :thumbsup:
Cam had one that wouldn't set the idle after cleaning. Mine is the same. I don't mind an 800rev idle in drive though.
Mine may not set the idle any more due to the engine light being on and the ecu in fault. It will drop the revs after the learn but the next time I start it the idle has raised again.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
