i didnt start the car but did turn the ignition to put the windows up while i went outside to paint the lights.. so that would be the problem then..
should i do a reset or will it just go away like you said??
thanks for the help..
Cleaned the MAF, Cleaned the Throttle body which was crazy filthy - you could see where the plate was pressing into the build up of gunk.
Re-set the ECU, and Idle (which was 1200rpm after the TB clean!) back down to 650rpm. much smoother and pleasant to drive. Surprised I got it all work 1st go!
Proceed to "test" up the Old Pac Hwy!!!:w00t:
I bought some second hand rims of kidafa. thanks. Well here is what the M35 looks like now.
Well I spent the day fixing gutter rash and then giving the rims a polish. Now the feel like new rims.
did it make a difference aaron?
i like the blacked out headlights. i might practice on the spare i have
like craigs except without the pokemon lazy eyes.
i was thinking of tinitn them.. bit worried though
NICE! Looks a heap better on your white 35 than my silver 34 imo....
May i ask how you de-rashed them?
There is a few tricks to this. You can file out the big marks and hit the smaller marks with some wet and dry moving up from a 240 grit to 2000grit. Once you hit it with some course polish and work to a nice fine polish, you wont notice the gutter rash.
I fitted my towbar to the Stag today. It's been sitting in the Garage waiting for me to do something for a few weeks now. I bought it second hand. I removed the goofy trailer plug and mount, removed some surface rust and gave it a coat of matt black rust stop. It fitted up quite nicely, but it looks like I need to get a new tongue made up as i don't want to cut up the rear lip. Failing that I guess I could space the tongue down by 15mm with a plate.
Thoughts/suggestions??
Had the car since end of Jan and this weekends been the first chance i've got to play on the car, only small stuff thou
1. replaced Cabin Filter
2. installed the Fm band expander (cardealer said they were going to put this in but didn't)
3. Pulled the DVD Rom out and Opened it up to physically clean the laser. Put i back in and now it works
so i can finally have the english conversion done (couldn't read the disc first time)
4, Installed a Reverse camera to the factory tuner, not essential but i figure if you have a Screen on the dash it might as well have a camera
Interior was in many pieces, but all when back together fine with only a couple of spare clips left over.
I did aciddently short the reverse light fuse and couldn't find the fuse to replace it.
wasn't to concerned and was going to sort it out later, until i tried to start the car and found out that it won't start without it
anyway searched the forum and learnt about the 3rd Fuse box hidden behind the battery on the firewall, so alls good again
i always thought the 2 fuse boxes i knew of didn't have enough to cover all the elec systems in the car
and It amazes me how they decided what areas of the Stagea needed to have English text and Japanese text on the other bits
Got the bastard file out and got rid of the rash. Then just sanded the whole rim from 200 grit all the wat to 2000. Then used a powerball and autosol. Alot of hours and sore arms but it was all worth it.
.....the 3rd Fuse box hidden behind the battery on the firewall, so alls good again.....
Easy job replacing the cabin filter? Did you buy a cabin filter from Ebay?
Where's the Second fuse box????? I know of the one behind the battery, I know of the one down near the accelerator pedal. Where's the other? :thumbsup:
i also need to do this so interested in the part number.
my Air con stinks and I have a feeling this may be apart of the reason lol
x-trail, 350z, and a few others fit our car. $25 from nissan. well worth it. i guarantee yours will be black aaron haha mine was filthy!
thanks iain. might do it while scotts attacking the exhaust in a week or two..
Iain,
Let me know if you have any of the centre console of the beige car handy. I still want to remove my 'out of colour' centre section where the stereo goes and replace it with something factory.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
