Dealt with them on a business level before. I think I'll give them a miss and go back to Pedders at ridgehaven. Didn't have time to get to pedders when I had the m35 done and went to tyre power on north east road.
If you can find a decent place stick with them! There's a reason I work on my own cars!
Try Discount city tyes 2 doors up. Chris does a lot of drift cars. Has done my M35 and GTR. The owner of ridgehaven pedders is good at his job but he is a d*ck.
I've got a set going in, my local Pedders recommended them and they can supply them as cheap as I've seen around.
They specifically recommended the eccentric ones so they could introduce more caster. Said it'd be awesome.
They specifically recommended the eccentric ones so they could introduce more caster. Said it'd be really good.
correction.....not a Nismo part! :P
Why Iain? Two cars have run on the Fcon so far, mine had issues only because the Emanage was also wired in.
Even so, the harness would be a good idea for anyone trying to fit an Emanage or any other standalone computer without hacking the loom...
good luck getting it working :P
It's pretty hard...
Disconnect battery.
Connect harness.
Plug in F con.
So far it's taken 5 minutes...
Reconnect battery.
Tune.
Done.
Which part of that was difficult?
Cam's didn't work because his fuel filter was blocked. Other than that it was fine in his car, but wasn't tuned beyond 4,500rpm.
I've had mine plugged in, and it worked, but I pulled it out until I could get a proper tune on it.
So far I've seen enough to know that there's no speed limiter, no throttle limiter, and you can retune to suit whatever mods you want to do.
= more awesome than Nismo! :nyaanyaa:
3 running Nismo's....0 running F-Cons!
Fail!!!
because neither of you have had it working properly. am i incorrect? or do you have new information that ive missed?
Fuel filter replaced and injector parameters changed back to stock size, the car ran beautifully for well over 1000kms.
Fail!!!
By default :(
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
