Hey Ryan what t10 led globes did you get?
http://www.ebay.com.au/itm/120782819640?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
They look pretty good, and delivery was fast.
I'd like to get some LED indicators too but doesn't look like I'm going to have much luck there. I am tempted to buy some of the T20s I've seen on ebay and try them - some claim to have a resister to stop the 'fast blinking' problem you can get.
Did the brake wire cut on the M35 today. Connected the wire to the reverse lights (thanks for that handy idea Leon) so everytime I reverse and hold the brake on a little the ECU sees the connection to keep the ECU/CEL happy.
Haven't test driven it yet, will do tomorrow and hopefully feel the results.
I initially wasn't going to do this mod until yesterday when I tried to jump across one lane of traffic and ended up sitting a couple inches higher in my seat lol.
:thumbsup: . I think I might do the same. I've done enough testing so no benefit in being able to switch it on & off anymore. I can't see any downside in leaving it on permanently. I mean, no one is forcing me to use it in anger... That will also free up a much needed switch position. Byebye fun switch :action-smiley-069: . And why a couple of inches higher in your seet? From butt clenching?
Oh, btw, with it connected to the reverse lights, the application of the brake has no bearing on things. So there could be an occasion where you will bring the CEL, but it's highly unlikely. Eg, you fill up your car & then pull out onto the freeway & don't stop (ie go into reverse) for 700km+ (driving reasonably economically). It may be that the ECU says 'why haven't I seen 12V from the brake in so long?' & throws a code. Good news is it doesn't seem to cause any problems, at least not straight away from my experience. And when you pull in for fuel & slide the lever into park, just pause for a second or two in reverse & you're clear.
Let us know your experience after driving with it for a while as there's been mixed reports.
Sitting higher as I stacked my dacks some what.
Thanks for explaining how it works a little more, no i u derstand why you guys had to tap the brakes when tou reconnect. The longest drive I do is around 250km to the riverland with a quick stop at my favorite bakery so it will see reverse quite often.
I'll post up my thoughts on it in a week after I have a bit of a play.
Cheers
Well the new RDA slotted discs and HPX pads went on with the new oil etc. on Friday as planned and feel great!! No shudders...
Had a meeting at Suzuki this morning, way out west, and on the way back drove past Niss4x4.... I wonder.... might they have a V35 coupe... And they did, and it had a stock exhaust!! $110 later it was off the V35 and in my boot.
6 nuts removed and less than an hour later with 5 of them refitted (removed the spare exhaust hanger), it is now happily under my car... Had to give the propshaft shield a gentle tap with the medium blunt object, but all good....
Loving the burrrrrrrrrrrrrrple on idle, no drone, and still very quiet on cruise..
Very happy man.. :thumbsup:
Edited by nickcorr
1329722005[/url]' post='6243330']
Great job mate. Easy isn't it!Best kept secret, can't believe nobody gave it a ago before me.
Slippy, it is the 350z that needs a bit of extension.
FINALLY Finally Finally after 3 years, and massive mess arounds and waaaay too much $ invested, I got the roof rail replacements fitted! They needed a ridiculous amount of prep work to get on (not naming names, but if I were the workshop who made these, I'd be ashamed to present it as a finished product), and the end ressult is far enough from from perfect that I'm pretty sure I'll crack it in the next year or so and have them re-engineered yet again for a better result, but it's still massively better than no rails! Am I ecstatic? nope, but still very happy that my car actually looks whole (even if it is from a distance)...
V35 ditches the 20kg box of baffles doesn't it? There's a huge benefit there alone.
Bloody hell I didnt realize it's that heavy. I wouldn't mind a better flowing mid pipe but need to keep it quiet to keep the boss happy. I like the idea of using the v35 mid pipe with the a/market dump and front pipe as it would flow a heap better than stock and still be quiet and a cheap upgrade.
1329726467[/url]' post='6243438']
Yup, it is a heavy bitch. Nick will back me up I'm sure! Can't say that I saw a difference in performance, but being na at the time, it's not surprising.Look, it's a cheap upgrade for those looking for a bit more note, bit more performance. It won't hold it's own against a proper aftermarket exhaust but I never said it would. It is a bigger pipe, with a resonator compared to a muffler. Hopefuly Nick should post some vids. I wouldn't compare it to my nismo though!
looks good micah, at least from a distance anyway.
Close up they're a bit rippled, and the fit is is a 9/10, but I'm happy for the time being....
Got done by the highway patrol man dam it , too low too noisy dam dam dam ,varex only work when u see the boys in blue ,the pain of it all , so today i got busted in my stag
the next day i ring the exhaust guy and the suspension guy dammmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
