Hey Ryan what t10 led globes did you get?
http://www.ebay.com.au/itm/120782819640?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
They look pretty good, and delivery was fast.
I'd like to get some LED indicators too but doesn't look like I'm going to have much luck there. I am tempted to buy some of the T20s I've seen on ebay and try them - some claim to have a resister to stop the 'fast blinking' problem you can get.
Did the brake wire cut on the M35 today. Connected the wire to the reverse lights (thanks for that handy idea Leon) so everytime I reverse and hold the brake on a little the ECU sees the connection to keep the ECU/CEL happy.
Haven't test driven it yet, will do tomorrow and hopefully feel the results.
I initially wasn't going to do this mod until yesterday when I tried to jump across one lane of traffic and ended up sitting a couple inches higher in my seat lol.
:thumbsup: . I think I might do the same. I've done enough testing so no benefit in being able to switch it on & off anymore. I can't see any downside in leaving it on permanently. I mean, no one is forcing me to use it in anger... That will also free up a much needed switch position. Byebye fun switch :action-smiley-069: . And why a couple of inches higher in your seet? From butt clenching?
Oh, btw, with it connected to the reverse lights, the application of the brake has no bearing on things. So there could be an occasion where you will bring the CEL, but it's highly unlikely. Eg, you fill up your car & then pull out onto the freeway & don't stop (ie go into reverse) for 700km+ (driving reasonably economically). It may be that the ECU says 'why haven't I seen 12V from the brake in so long?' & throws a code. Good news is it doesn't seem to cause any problems, at least not straight away from my experience. And when you pull in for fuel & slide the lever into park, just pause for a second or two in reverse & you're clear.
Let us know your experience after driving with it for a while as there's been mixed reports.
Sitting higher as I stacked my dacks some what.
Thanks for explaining how it works a little more, no i u derstand why you guys had to tap the brakes when tou reconnect. The longest drive I do is around 250km to the riverland with a quick stop at my favorite bakery so it will see reverse quite often.
I'll post up my thoughts on it in a week after I have a bit of a play.
Cheers
Well the new RDA slotted discs and HPX pads went on with the new oil etc. on Friday as planned and feel great!! No shudders...
Had a meeting at Suzuki this morning, way out west, and on the way back drove past Niss4x4.... I wonder.... might they have a V35 coupe... And they did, and it had a stock exhaust!! $110 later it was off the V35 and in my boot.
6 nuts removed and less than an hour later with 5 of them refitted (removed the spare exhaust hanger), it is now happily under my car... Had to give the propshaft shield a gentle tap with the medium blunt object, but all good....
Loving the burrrrrrrrrrrrrrple on idle, no drone, and still very quiet on cruise..
Very happy man.. :thumbsup:
Edited by nickcorr
1329722005[/url]' post='6243330']
Great job mate. Easy isn't it!Best kept secret, can't believe nobody gave it a ago before me.
Slippy, it is the 350z that needs a bit of extension.
FINALLY Finally Finally after 3 years, and massive mess arounds and waaaay too much $ invested, I got the roof rail replacements fitted! They needed a ridiculous amount of prep work to get on (not naming names, but if I were the workshop who made these, I'd be ashamed to present it as a finished product), and the end ressult is far enough from from perfect that I'm pretty sure I'll crack it in the next year or so and have them re-engineered yet again for a better result, but it's still massively better than no rails! Am I ecstatic? nope, but still very happy that my car actually looks whole (even if it is from a distance)...
V35 ditches the 20kg box of baffles doesn't it? There's a huge benefit there alone.
Bloody hell I didnt realize it's that heavy. I wouldn't mind a better flowing mid pipe but need to keep it quiet to keep the boss happy. I like the idea of using the v35 mid pipe with the a/market dump and front pipe as it would flow a heap better than stock and still be quiet and a cheap upgrade.
1329726467[/url]' post='6243438']
Yup, it is a heavy bitch. Nick will back me up I'm sure! Can't say that I saw a difference in performance, but being na at the time, it's not surprising.Look, it's a cheap upgrade for those looking for a bit more note, bit more performance. It won't hold it's own against a proper aftermarket exhaust but I never said it would. It is a bigger pipe, with a resonator compared to a muffler. Hopefuly Nick should post some vids. I wouldn't compare it to my nismo though!
looks good micah, at least from a distance anyway.
Close up they're a bit rippled, and the fit is is a 9/10, but I'm happy for the time being....
Got done by the highway patrol man dam it , too low too noisy dam dam dam ,varex only work when u see the boys in blue ,the pain of it all , so today i got busted in my stag
the next day i ring the exhaust guy and the suspension guy dammmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
