I have been tinkering with underbonnet temps and air intake temps lately and had a go at making my own air intake.
I already had made a perspex heat shield quite a while ago, but there was nothing to help get cooler air to the filter. Our cheap, nasty mistral dryer karked it the other week and when it did i noticed it's air duct at the back was quite nicely shaped. But it wasn't long enough to do what i needed.
Oh, Hi there black plastic garden barrier roll !!
So i cut up various shapes of plastic to do what i needed. Then I used a heat gun to shape the plastic to the dryer intake and to clear engine bay stuff. Glued it all together and sprayed some matt black on for good measure.
It definitely works. On the highway, i can feel a quicker response from the engine. Would love to run a temp probe of some sort and do back to back testing with it on and off so i have some figures to match what i think is a very positive improvement.
post-58831-0-49410200-1330504937_thumb.jpg post-58831-0-80538300-1330504949_thumb.jpg post-58831-0-87838900-1330504956_thumb.jpg
The other thing i have done, is cut away a section of the rubber at the rear that seals the bonnet to the engine bay. This is on the exhaust/turbo side and lets alot of hot air out. After stopping the car i can tell the difference just by touching the bonnet in different places. It's alot cooler at the air filter end, and just warm at the turbo/exhaust end. I've felt my bonnet temps for along time prior (just for curiosity - ok, i'm weird) and this small mod has definitely helped alot.
Nice one Jezza :thumbsup: . Stuff like that provides maximum bang for buck because you hardly spend a buck (just a bit of time).
I couldn't let it pass without giving you the thumbs up; my sig says it all.
Thanks heaps Commsman. Ok this one's for you then
Take 2 -3 old 3.5" Desktop hard drives. Dismantle, and retrieve awesome magnets. Link together with wire and wrap around oil filter.
post-58831-0-76312200-1330507420_thumb.jpg post-58831-0-25674400-1330507427_thumb.jpg
Now people are gonna say, whatever, there's alloy filings that it isn't going to get etc.... well non ferrous metals can still get energy from friction motions (crankshaft rotation etc) so they will be attracted to a magnet.
Haha. ummm, yeah, that does qualify I suppose.
I'd be concerned about that bouncing off under the car & giving me a mild panic attack as I (however briefly it may be) think something important has busted & fallen off. You probably won't see that one appearing on my car anytime soon, but I'm sure it is effective nonetheless. Looking thru the emoticons for a 'half thumbs up', lol, but no luck.
HDD magnets are absurdely strong, they wouldn't 'bounce' off imho :P
Oh?
Ok then, Jezza :thumbsup: for you recycling junk into performance & maintenance enhancing thingos.
Norwood Auto Services dropped off the car this morning...
New ball joints
New SuperPro bushes
New SPC camber and toe bolts
New adjustable rear toe arms
Handling is much improved. Much less freeplay than previously, feels great.
Still feels like it pulls to the right, going to switch the front tyres around tomorrow and see if that fixes it. Regardless, I'm going back next week to get wheels and tyres sorted, so all good.
Also test fit the new wheels, fit perfect. 18x8 +34 Braid Winrace A, white. In stock with SA Motorsport Tyres, Just trying to decide on tyres now. Looks like 235/40 R18 of some description.
Had plenty of time to drive it, 800k's over to Calder Park for Rally Calder this weekend. Cruise control is a godsend Leon! Works great!
White on white hey.... look forward to the pics when fitted.
Why so small on the tyres? Is 235/40 a common size for ones you're considering? 245/45 is much closer for speedo accuracy, plus a bit of extra sidewall to absorb big holes. Of course if you want more of the low profile look then they would be ok, but I'd consider going to 19's if that"s the case.
Yeah, I'm loving the cruise too. I use it nearly every time I take the car out.
PS For those last few guys waiting on theirs, I'm in contact with my buyer every week & they assure me they are going to be sent soon. I think the factory has discovered what country they are coming to & is taking their time sending the last of the harnesses, just to punish me.
They did look good on the car but we ran out of time to do it on Tuesday.
235/40 looked like it'd measure faster than 245/45 but I'll check when I get home again. not really after low profile, more the right size. Staying 18 though.
+1
With that offset you can easy fit some 245s in there. Do it. Fill the guards with rubber!
Ryan on my 18's I run 245/45-18 and the speedo is now only out about 2-3km instead of the previous 10km I had measured. Deffinately go a 245/45. So when the speedo shows 60 I'm now doing about 58 actual speed, before it was closer to 50 actual speed when speedo showed 60.
Can you get those wheels in a +20? I think they will sit in the guard a little to far in the size your looking at. Not sure if you remember where mine sit but the size your looking at will sit inside another 16mm from my 18x9+30. Mine sit very flush and don't scrap at all with my tyre size and ride height.
Edited by slippylotion
Weird that yours was so far out, must have been the snow tyres. Mine is about 8% out I think.
will go the 245/45s, just limits tyre selection.
245/45/18 is OEM VE Commodore sizing; plenty of reasonably priced choices in that size.:thumbsup:
All good Paul, happy with the offset on mine. Look good!
Thanks for that Dale. Of the two tyres I'm looking at, one comes in 245/45, one doesn't. Cheaper one does!
I have been thinking of doing something like that for a while but can't bear cutting away stuff, good idea to dump some heat out there. My bonnet lining was getting all tatty looking & fibres dropping out onto the motor so I removed it, bothers me that the paint is feeling more heat. Still heat can radiate out better and a bit more air space.
Back in the jurassic era when my old holden 186 turbo roamed the earth, under bonnet temp got way higher than any of it's peers. The 3" dump pipe and Rajay turbo scroll and cast manifold would regularly glow cherry. Think I had spacers under the bonnet hinges to lift the back a little.
Is this the factory Bose spare wheel sub into a non Bose factory head unit? Please PM connection details if it is.
Cheers
Hey guys
it really wasn't so difficult. All you need is to find the wires for the power, earth, remote and speaker and fiddle with it. I had it connected into the amp so it didn't come directly from the HU. It still uses it's in-built amp though.
It honestly wasn't hard you just need the patience to still there and play around with it.
received my order of LED T5 globes for dash last night. work really well :D few darker spots but better then previous cars i have had.
also received my front and rear strut braces today. :D fitted, but need to loosen up rear sway bar i think, went from understeering a fair bit to oversteering now. otherwise still plenty of fun :D
Here's what I've done to the car since purchase...
Hdi FMIC, Transgo shift kit, Brembos from 60th Ann 350Z, custom 3" exhaust with Scotty's dump pipe, uprated sway bars from Selbys/Fulcrum, PWR transmission cooler, LED daytime/fog lamps, air horns above FMIC.
Still to do - bonnet strut kit (no garage and it's been raining constantly in the Mountains), EBC, possible info meter and double DIN DVD/CD + reversing camera + navigation. Considering a Scheel drivers seat I've had since 1988, big wrap around shoulders and still in good nick. It's migrated from car to car.
Some new wheels to replace the T7s.
Attached is a photo taken before the foggies and transmission cooler.
More photos to follow.
Edited by rosella
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
