Lol, but how would I get the cams to work?
VQ25 FTW... :thumbsup:
Just sleeve yours out! Wouldn't that work? Then just use some of the darton sleves with some bigger pistons / tomei rods and bolt it all back with your heads.
Work or not?
Your growing an engine farm down there, so just build one of the spare short blocks!:P
Work or not?
I could sleeve it out, I have a 3.5 engine here too, but why would I want a longer stroke or a larger piston when i'm making 335kw already? C'mon mate you really need to catch up... :nyaanyaa:
I will probably drop the 2.5dd in if this engine ever retires. High comp, e85 and direct water injection to control the piston temps. :whistling:
1333811397[/url]' post='6307077']
Did you want the dyno queen status, or want me to go faster than 13.9? tongue.gif
Hahaha. Think your car is good for it Alex? Wind the wick up and see what she will do, you got to beat 13.5. Can you take off with wheelspin yet? >_<
My takeoff would be fixed by simply opening up the stator on the torque converter but I don't want to go down that path. I want a fast street car not drag.
Lol. Yeah it actually does it I launch it with full boost. Maybe a product of the single spinner buttongue.gif
I have too much mechanical sympathy to flog it hard. I'm going to order some stuff, and then back to the tuner. Might go to the track in between though. Craig has to get to the tuner- cause he want to post a time too with the emanage in.
Was looking at my rear badge i removed and found a better spot for it
Painted the slats after the side rear windows black and the lower section of the dayz rear bar black also.
post-58831-0-86517300-1333957505_thumb.jpg post-58831-0-89643500-1333957489_thumb.jpg post-58831-0-99769800-1333957497_thumb.jpg
and in an attempt to get to the bottom of why my rear sunroof doesn't quite seal all they way, i fully stripped my rear interior. Haven't started looking into rear sunroof yet LOL
post-58831-0-55501000-1333957327_thumb.jpg post-58831-0-26374200-1333957336_thumb.jpg
Car needs a bloody good wash now but i'm buggered. fk it
Be interested to see more photos of the roof when you get time. Don't you hate it how you have to start from the bottom and work your way up.
Haven't fully removed roof lining yet but am going to. Here is shot of the rear roof section that i've removed the lining from.
I was a little frustrated at first and then I quite enjoyed stripping everything out as there was alot of heavy stuff !! I also found a japanese receipt under the rear seat (anyone know what it is from ?)
I also sanded and polished my neo badge as it was unrecognisable !
what did you use on it? mine looks pretty crappy too
also, i think that receipt could be for fuel
I first used 1200 sandpaper on a block of cork. Then I used a scotch brite pad with autosol, lastly autosol and a rag. I also polished up a dull front head light with autosol and a polish mop on my 18v ryobi drill.
Fuel receipt eh ? cool !
Before with tomei M7655 twins which were laggy and very tame onto boost
Now with the GT3582R (.82) rear, precision 48mm waste gate ,Platinum Pro ecu, 044 fuel pump and ID1000's. Should be a big improvement. hope the clutch holds up
Booked into Tuner on the 24th may
New hi-flow turbo in transit to me so was under the car to pull out the old one with the blown oil seal. The first thing I see was a split drivers side CV boot & the grease spun out everywhere. Great just what I need - more work.
Then, over on the passenger side I see this:
I wonder how this got knocked out of centre?? So, what's the recommended fix? (Big hammer, lol).
Found a small stone chip in my drivers side headlight today. Fuuuuuu.....
Considering the $2500 cost from Nissan, I've live with it. Its small and over the indicator, no hole or anything just a little crack.
Felt so sorry for it, spent the next 45mins or so polishing up the headlights to keep that nasty yellow shit away. :rolleyes:
That is exactly the same as my passenger side. Im putting in new ones tomorrow I just had to wait to get on a hoist. I wouldn't bother hitting it I hit mine back and within 2 days it was back.
Yep; the centre has been torn out of that bush. She's f**ked.
Leon, I've got a fresh set of Whiteline ones that were due to go into my car shortly; if you like, PM me, and I'll send 'em up. :thumbsup:
Edited by Daleo
Thanks Dale, I'll PM you for details.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
