^^^ Bargain price. My guy charged me a little more & I supplied the boot.
Obviously a discount was given for the thrashing test drive, lol.
Meh, he only drove it about 2 km; not much thrashing in that distance...
Nice one. How come you didn't tackle it on your own Dale?
I knew it was only going to be $100- $150, with a boot at $30-$40; it wasn't worth my while.
I'd rather save money on things I actually enjoy doing.
Like turbo changes...
damn smart call.
even though I *can* there are a few jobs I am happy to get done. CVs is definately on that list
Yep; I've heard of so many people having to rip them back out, to re-do the ties.
Not interested.
I dont blame you on the cv boot.
Anything involving packing grease or chance of spilling more fluid than a normal oil change is banned from being done in my garage.
After accidently dropping a full cressida auto trans off my bench after swapping out the dud, cleaning the mess with that gave me the CBFs with anything messier.
I installed a water to air intercooler on the stag over the last couple of afternoons. The boost response is out of this world compared to a front mount!!!
now that is a big job.....muuuch more detail needed :)
maybe a whole thread ;)
I have a w2a intercooler in a race car I never got around to finishing....
+1 i'd be interested in seeing that too
also, anyone know what its called when you mount the fmic right infront of the rad and move the rad back a bit?
i've seen it done on an s13, makes for super short plumbing!
Okay, I'll attach some photos It wasn't a big job really. What I will say is that it's still a work in progress. There are still a few things that need tidying up to get it how I want it.
The number 1 thing on the list is to install another radiator, I got the kit second hand and the radiator was unusable, so for now I turned up some adaptors and I'm just using the FMIC as the rad. It looks ugly, but it works well. I have a brand new Barina rad here to use, that's it I don't get a specific one to suit the kit.
A guard for around the back of the pump is on its way. Hopefully I'll have something made up by the weekend.
You will notice that the black 90deg reducer bend is a little deformed. This is because the bend is not sharp enough. I bought this from the local parts store as it was all they had. The blue one is from frozenboost and is a much tighter bend. I will try and track down 2 black ones, if I can't find any I will get some from frozenboost. Once I have some tighter bends I should be able to move the intercooler over enough to clear the overflow bottle. I may need to make up some custom fittings that don't sit as proud and also re rout the BOV return to give me a bit more room.
Eventually I may go to Aeroflow push on fittings and hose. I just used standard heater hose which can be a bit prone to kinking but is fine once it's in place kink free. I was a little wary of pressure buildup in the system but my concerns were unfounded. The whole system runs only slightly above ambient and you can't feel any pressure in the hoses even when hot from heat soak.
I drilled and tapped 1/8bspt holes for 2 8mm barbs. One you can see in the pics in the top right hand end tank on the cooler. The second went in the top of one of my front mount tanks. This was to allow all the air out of the system when filling. Without this all the cambers in the system would have only filled up as far as either the inlet or the outlet, whichever is higher. I run some vac lines, teed them up and attached them to the filler body.
It is a bit of a squeeze to get it in but I think it fits reasonably well.
The kit is from frozenboost.com It's their 600HP kit
Edited by Race__24
installed my ox rear underbody brace last saturday and today installed my hdi duel stage boost controller at 10psi and 12psi settings
Why so low boost? I thought stock was 12psi, 14psi on Axis.
Needs moar boost
Yeah i wasnt too sure what the stock was. I was just trying to play it safe i guess till i install my front mount and full 3 inch exhaust. Cheers for the info
well ceramic turbo's can only handle 14psi so it's up to you what u want to load her up with i run16-18psi.
but airbox/fmic and exhaust will raise it up 4psi cos its nice and free flowing
So, the saga continues: 4th dyno run, 4th time lucky, right? Thus far, I've had a blocked cat (run no.1), dodgy gasket (run no.2) and blown the rear turbo (run no.3), all this after my you beaut PWR radiator disintegrated due to poor workmanship.
So, 4th time lucky??
Not on your life! This time it looks like we managed to crack at least 1 piston, but I guess that's the joys of modding lol!
So, back to the mech (yet again) for a fresh, forged set of internals, then we'll show it some decent boost. It lasted damn well for an internally stock engine (it was making 420hp@wheels for about 5 years or so) that had unknown history before I got it...
What this means is my budget for the Toyota 86 has taken a fatal beating, so I guess I'll find another decent daily for the next 12-18 months: looking at a Y34 Gloria/Cedric...
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
