They installed a Turbosmart Boost Tee that day because the EBC was playing up... I can't really tell you how it is hooked up sorry :/
Other mods are:
Greddy Front Mount Intercooler
3" Full stainless steel Fujitsubo exhaust and stainless steel front pipe with 3" Venom 200cpi hi-flow cat
Nistune ECU
Nismo High-Flow Volume Fuel Pump
HKS Panel Filter
well it is definately an issue with the boost controller or it's plumbing, hopefully they aren't getting you to pay for labour while they learn to do it properly. Boost control is a pretty simple system
Just got some Michelin Pilot Sport 3s put on my car and a full alignment - it already feels like I'm going to love these tyres! More compliant than the Federal 595s, decently quiet (roughly the same as the Feds), and very confidence inspiring so far. Can't wait to put some kays on them and give them some more stick and also try them in the wet.
Lol dude, same here.
One of my all time, least favourite bike tyres...
+1 for that had them years ago on zzr swore i would not have them again then when i got my old gsxr it had them on it but not for long.
Running kuhmo ku36 on the stag at the moment 19s and i really cant complain they stick well wet or dry bit noisy but after gate has been opened a couple of times i cant hear s@#t any way , and they where cheap to boot
Havent done it to it yet, but I bought a new high pressure hose from bunnings which also came with a foam lance... the only rare occasion that I have been excited about cleaning the Stagea..
Edited by S T A R 3 3
So it is most likely a leak somewhere? I would be surprised if they didn't install the Tee properly, but then again stranger things have happened...
^^slight leak from turbo manifold gasket?..thats what mine was, never held boost up top since i imported it
thought it was my faulty ebc,as it had been sitting around for 6 yrs , put on bleeder, same shit
cheers
darren
Edited by jet_r31
Installed a JVC KDR736BT deck in the Stagea. A big thanks to Kenwood and JVC for using the same loom plug barring a single pin which is devoted to the (not in use) remote button/steering wheel control. I had the soldering iron, heat shrink, electrical tape and other bits and pieces out but all I needed was a phillips head screwdriver. :yes:
JB Hifi have 30% off headunits so it was hard to knock back this unit at $122 vs $178 or the alleged rrp $349. The neat thing about this deck is it can connect two phones at once and a more modern IPod/Iphone control than the previous Kenwood deck.
I picked up my new M35 last Friday :)
After a 6-7 year absence from owning an import I am back and happy as Larry.
I'll post some pics after it stops raining and I've had a chance to give it a wash.
The storms here have been arse up. The worst ever.
Had to get the SES to come and chain saw the trees in the driveway so I could go to the bottle shop.
Damn inconsiderate of Mother Nature.
Was so blest the tree that came down just missed the Stags in the drive.
lucky!!! hope it all goes well and stay safe!!!
inconsiderate? but now you have fire wood for winter and someone came and cut it for you
hope everything is ok up there, pretty wet down the bottom of the hill but not much happened here
Damn those Swedes and their keenly priced flatpack temptations.
And their carpark.
I resent that.. ;)
Too bad about the paint though.. What was the cause?
Edited by Miltuun
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
