Jealous low blow Scott!
Just because you have no wing!
I can now hang out with EVO-Tards!
P.S. Where's my front Bar Theo! :P
we threw it out cos it was farked..........
After a bit of an epic getting it on, finally have scotty's dump fitted, boost picks up nice and early and pulls much better in the mid range.
Cheers for helping the mechanic's out too Scott!
Nick
Ps at what point should one look into, or should I say require some electronic wizardry... emanage, tuning boost control... that sort of thing?
Edited by NickM91
Not sure what u are getting at Jetwreck. As in new turbo? Hi flow etc, because the latter has already been done.
Footo, yes we shall, ps when was your car white (avatar)... haha
Edited by NickM91
Once you change the turbo, the ecu isn't mapped for the extra flow and dumps fuel to compensate. When you hit the windscreen on airflow cut, it's definitely time to drop the cash on some tuning.
Anyone live near blacktown and want to be my plan c?
trying to grab a bargain and i'll be coming through sydney in about 10 days
so if either of my two friends can't get to it who would want to pick up some suspension for me and pay for it (its retardedly cheap at $100) and i'll give you the money when i come down plus something for your troubles
Contact me closer to the day, Tom. I'm not far from Blacktown but... (see below)
I went and got a quote today to have my passenger side mirror rust cut out/repaired, as well as repair/repaint my rear bumper where I hit it on the bollard a few weeks back, and also repaint and attach the rear wing I just bought. Booked in to be dropped off in just over 10 days.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
